Evening. Has anyone installed a compufire ignition module in a late model type 3? I've got a '73 wagon and have bought a module but it don't fit. My dizzy has a post which needs to be removed and the module has lug on the bottom which is suppose to line up with the hole, but it don't.
Oh well, back to points I 'spose.
Neil
Fraid so Neil
Or change dissy to one which uses GB534 points.
njg02 ·
It's funny. You ask the seller if it will fit. "umm yeah". Back to Sydney for refund.
I'll check around and see if I can get an equivalent dizzy.
Thanks.
You need a German made dizzy. I'm pretty sure the one you have would be a local Bosch one.
njg02 ·
How can I find out? Some numbers that I can see are;
9 230 061 400
312 905 205 Z
It will have made in ?? written on it. But 312 905 205Z is a locally made dizzy. I'm not sure but maybe you could pull the post out of your base plate?
njg02 ·
Made in Aus. I should be able to pull the post and redrill for the lug. But! I might put up with the points for a while.
Would the plate swap with a german dizzy? Or could I swap the lot?
Neil
jo_tas ·
Mine (late type 3) was a bolt in job.. I guess i have a german distributor?
njg02 ·
Thanks jo_tas.
Neil
Klaus ·
I've probably got some dizzy's you could use . I've got a 009 that caught fire due to busted fuel hose which has burnt condensor and cap which you could use, should be home all weekend playing with cars . 0428 427 986
