wtb for lend: 1x porsche wheel
https://forums.aussieveedubbers.com/threads/65430/wtb-for-lend-1x-porsche-wheel
bond ·
am wanting to borrow/lend 1x porsche 5x130 wheel.
preferably 15x7. ideally a fuch if anyone has one in that size?
if someone happens to have a set of 4 in brisbane they are willing to lend for a few weeks then that would be greatly appreciated.
nick
0422 721 253
555bug ·
nick you can get a 17*7.5 off me but these have a 52et off set. If you want earlies I think they run a 23et off set.
Stephen
OZ Towdster ·
I'll see what i can do
2443TT ·
Hi Nick,
You can fit a 15x6 on the front brakes with a 16mm wheel spacer and it clears the calipers by about 2-3mm. To get that to fit under stock width guards my front beam was narrowed 2".
The rears would be the same if using 6" rims. 7's wont fit unless you widen the guards, or run 16" boxter rims so they clear the calipers.
My 15" setup with the fuchs has type 3 drums on the back on short axels, and i had 15x7's then.
My 17" setup also ran the wide spacers, but that was to keep the wheel track, not to clear the calipers. I reall needed to add those 2 inches back to the beam instead. Would have made for better steering geometry.
With the 944 rear end setup on short axels i ran a 12mm spacer on the rear so the tyres cleared the spring plates still, and ran 17x7.5's on the back.
I hope that helps!
Ian.
11CAB ·
I've got 4 15x6 Cookie cutters if that helps....
bond ·
thanks ian - the 15x7s are for mockup purposed only. thanks to mr a westwood, have sourced a 15x7 cookie cutter which i beleive has the offset of some fuchs of a similar era +23.3mm.
i will get a set of 17x7 rims custom made to any offset.
graham - appreciate the help - wont rule you completely out yet! may ask the favour down the track as to roll the pan around untill the wheels i order arrive. will give you a call tomorrow re: tank.
thanks guys - help is greatly appreciated.
nick
h ·
nick.. get it on man, as dubs isnt too far off..
look fwd to seeing your ride in the line up.. 😉
