Hey need some help, went to open driver door pushed the button in, heard a click, then something drop, door wont open from outside, opened it up and found, seems to be a broken washery thing. Any help greatly appreciated~ thanks
Sime~
greedy53 ·
could you please use non tecnical terms so we can figure it out dam education always gets in the way
Click the doobie near the popper and it will grab once the edge is sorta grooved. 👍
s-deez ·
non computing~system overload~🤪
Drivers door will not open from outside, push button stayes in, can only open from inside!!thanks
pod ·
sounds like its time for a new door mechanism 👎
Yes,
You will have to replace the complete door lock mechanism
If You haven't seen one...
its a very complex complicated lock that is not repairable
mainly, because no one can figure out how it works😂😂
greedy53 ·
i have a few handles with the guts sa i have taken all that kinda stuff of i it's any help i can send you pay post only
its the large complicated looking piece
in behind the door handle lock...
I've never pulled one out so all My spare doors would still have them there...
s-deez ·
Thanks Guys~,
so can I still use the exterior key lock part, or do I just have to replace it all~ cheers
Sime~🥲
outside door handle and key are all OK...
its just the mechanism inside the door...
usually the door handles don't give any trouble...
take the door handle off and press inside the square hole with a screwdriver or strong finger to see if the mechanism is at fault...
the outside door handle is pretty simple...
not many parts to fail...
s-deez ·
Thanks LEE~
Something else to play with, cheers
Sime~
