Got time this weekend to work on the barnster....so put some hours...
Firstly I cut away barney's passenger side dogleg. Below you can see the rust/rot in the bottom of the front pillar that was 'hidden' by the old crusty dogleg...
Rust in the rear pillar was also masked/caused by the crusty dogleg. It was also suspect in the top left hand corner under the floor...just a little bubbly but it will have to be fixed!
Repaired the bottom of the front pillar. Had to fix the lower inner structure as well...
The 'finished' front pillar repair...
Repaired the rear pillar.....you can probably see the patch in the top left hand corner (under the floor) too....
That corner repair from above....
Worked deep into the night *yawn* and got the new dogleg fitted. Its a brazilian repro of a 'late' dogleg that I bought from Guy Harding. Guy warned me that they were 'difficult to fit' (which I knew, not unusual to have to unpick them completely, fit and weld em together again).
Spent a lot of time measuring and pondering...and yes they are sorta 'twisted' as supplied. Thought it through and reckoned that if I unpicked the top edge and refolded it I would basically straighten it up and it worked pretty well. Gaps are nice and even if slightly wider that I'd like at 3 mmish (but the gap behind the door which is fixed is that wide so it all looks balanced)....
I now have to modify widen the 'lip' on the dogleg (early busses were wider above the wheel well...)...
If you want to see slightly bigger pics you can see them by clicking on the links below..
http://users.pipeline.com.au/hoopty/barnbody19.jpg
http://users.pipeline.com.au/hoopty/barnbody21.jpg
http://users.pipeline.com.au/hoopty/barnbody22.jpg
http://users.pipeline.com.au/hoopty/barnbody23.jpg
http://users.pipeline.com.au/hoopty/barnbody24.jpg
http://users.pipeline.com.au/hoopty/barnbody25.jpg
http://users.pipeline.com.au/hoopty/barnbody26.jpg
later gators
RobK
[Edited on 19-5-2003 by splitbusaustralia]
splitbusaustralia ·
