i am planning to build a nice 1916 for my 1960 bug
since it is going to be a bit of an og-ratty i would like to make it look as stock as possible from the outside(sleeper?!)
so i wanna try to use the og cutouts in the rear apron without restricting my engine through the exhaust system
has anyone got any ideas what to use or and where to get it
any help appreciated
thanks
steffen
squizy ·
There's a nice euro tip exhaust on CIP1 (and other sites) that's going around - it's a bolt on and has two nice rolled tips. Comes in black or ceramic coated. Or you can spend more bickies and get a custom job done.
cram ·
steffen, also check out the CSP website...a bit pricey though.
the extractors I have wouldn't suit your application.
What sort of HP you aiming for??
This is better than a stock exhaust but certainly not in the fully merged header area.
I am running one on a base 1916.
Caffinepusherman is also running one on his KG with 1916 and dual webers.
Am guessing it would be "acceptable" on a ....say 70rear wheel HP motor.
If you are going 044's and big valves and lumpy cam - forget it
Bizzare, is your car up on ramps so that you can clean the exhaust with a tooth brush? Very clean indeed.
Another way to go is a decent 4 into 1 header, then some bends to put the muffler next to the heater box on the drivers side, then some more bends to bring it out the stock exhaust holes, just like an old Brabham Lukey system.
happy with mine never scrapes car is seriously low nice note build quality is ok but for the price i'm not complaining works well with my 1916 in the ghia😀
CAFFINEPUSHERMAN ·
the black bitch
CAFFINEPUSHERMAN ·
more
CAFFINEPUSHERMAN ·
spot the difference🙅😂🙅😂🙅😂
Special Air Service ·
1303Steve wrote:Hi
I have the same system as Bizarre & caffinepusherman & am very happy (only on 1300 though). In the future I am contemplating cutting the muffler off at the end of the collector & doing as 1303Steve has described, these particular headers are stainless & the collector is closer to the rear of the engine than the normal 4 into 1 systems & as a result there is more room to move with all the additional pipework needed.
Brendan
StenGuns ·
Barry.. This is just what I am looking for.. Where do you get them?
Bizarre wrote:What sort of HP you aiming for??
V Force or classicveedub
StenGuns ·
Special Air Service wrote:V Force or classicveedub
VWFREAK ·
George has got them at Classic VW, I put this set up on Taz Devils 69 beetle about 10 months ago. Good price as well
