FS - SA - Split rear window kit / fiberglass *SOLD*
https://forums.aussieveedubbers.com/threads/65627/fs-sa-split-rear-window-kit-fiberglass-sold
57 Cal look ·
Seller's Name – Finn.
Contact: u2u or mobile : 0420682979
Suburb / Post Code – Golden Grove. SA 5125
Item Description: Bought from Wizard roadsters before they went broke. Never installed, so it is as new condition.
you get inner & outer pannels, window glass, window rubbers, bonding adhesive & instructions.
Item Cost: $300.00 ono
Shipping: i am happy to ship it anywhere at the buyers expence
First to hand over the cash is the buyer, i will not "hold" the item.
bushed ·
pls explain..it looks like it will cover a non oval window and the air vents for engine...
or do you cut rear roof out?
bushed ·
i dont understand the other panel
wont see out the window...i dont get it, sorry...interested though for my 56
vwtyp2 ·
it involves cutting the back out of your car and replacing it with these panels.
one is the inside panel, and one is the outside.
You obviously cut the centres out of the window section of the inside panel.
57 Cal look ·
VWTYP2 is 100% correct, this is a conversion for a big rear window beetle.
you cut down from the bottom of the rear window to the bottom edge of the air vents. then bond in the inner & outter skins, once they are bonded, then cut out the window holes from the inner skin & the air vents from the outer skin. pritty simple stuff really.
its not something for the purest, but if you want the split window look, then ......
bushed ·
as i th't big window version , nice but no good to me 4 ovl thanx
Dero ·
hhmmm could be interesting for a Baja Bug....
Pumba ·
What year model with big window will this suit,I have a 63 or is it for the later ones cheers shane.
57 Cal look ·
Fits 58 - 69
