wheel spacers
https://forums.aussieveedubbers.com/threads/65747/wheel-spacers
waltermitty ·
Hi all, Im back from my trip.
I wish to installl a set of audi mag to my T3 dualcab.
Can anyone help with wheel spacer size the mags are 7 inch with 45 et and standard wheels are 6 -6.5 inches with a 30 - 40 et for either sreel or factory mags.
Any one know a a web site that does cals ar can work this out.
Thanks in advance mitch
bond ·
this may help.
http://www.germanlook.com/Forums/showthread.php?t=6580&highlight=offset+calculator
maybe try contact this guy.
http://www.germanlook.com/Forums/showthread.php?t=5911&highlight=offset+calculator
nick
Mitch
Palace - now!
Glad your back. Love to hear the tales and woes of the trip.
As for off set and fitmant - a bit of playing is required.
Use this calculator.
http://www.1010tires.com/WheelOffsetCalculator.asp
Comparing a 6" 30 ET with a 7" 45 ET you are 28 mm furter in.
But you need to work out how much clearance your existing wheel has both on the inside and outside.
Measure what clearance you have now - inside from the springs etc and outside from the lip.
rocknrob ·
spacers and/or longer studs is a messy and exy way to go...get a set of merc wheels or late model falcon(some machining) 35-37 ET
