Sounds good that it has the upright kit and fan,
But that "bush in Flywheel " comment is a bit worrying.
Let us Know how it goes together.
Grey 57 路
can't wait to see it in full fly't mate.
:thumb
OvalGlen 路
and so good that its a VW motor and not some Japanese or other type that belongs in a different Make of car...馃榾
nbturbo 路
Good move going Type4.What kit are you using for your fan shroud conversion? If it is Mikes from Sharpbuilt,he supplies a bronze press in bush-its OK,but for a small cost you can buy the original Type 1 needle roller bearing and have your flywheel drilled to suit it.I have used a 215mm Type4 flywheel and it fits OK into a 12volt Type 1 transmission.I have used the trans with the support for the release bearing so pressure plates are easy to get.Any 12volt VW starter will work with this flywheel.Good luck.
Golde60 路
yeah, i will cross those bridges when i come to them.
i know about the options, but the car its going into is far from complete.
it will be having the spigot pressed in, and i dont really know how to do it all, but i m sure i will get the right advise.
i beleive that an 1800 flywheel will fit into my 1500 bellhousing.
