wanted early type 3 swing wagon torsion bars
https://forums.aussieveedubbers.com/threads/65852/wanted-early-type-3-swing-wagon-torsion-bars
vwsteve ·
i am chasing a pair of early type 3 torsion bars off a swing axle rear wagon, please call steve on 0409475131, cheers
If you don't have Type 3 spring plates, you will need them as well.
vwsteve ·
I have aftermarket h/d spring plates to replace the twin ones on my irs pan, i have been told the irs torsion bars are longer and with the spring plates i have i need the shorter torsion bars?It is to get rid of the extra bit sticking out so i can put bigger wheels on my baja.
mackaymanx ·
You need Beetle bars from what you are saying, the type 3 swing axle torsion bar/spring plates still stick out enough to cause problems with wheel clearance. There are three different lenghts, swingaxle beetle, swingaxle type 3 and type1/3 IRS in that order. What springplates do you have.
vwsteve ·
I have the irs bug ones at the moment, i thought early type 3 would be the same length as early bug bars but it sounds like they are not unfortunately, i was hoping to stiffen the rear up.
bushed ·
found a set look like swinger beetle as the ute has the axles also etcamong apile of splitty stuff so if
send me the measurements u want I will check
