kombi bits
https://forums.aussieveedubbers.com/threads/65941/kombi-bits
James ·
Kombi 1600 IRS gearbox with automatic locking/unlocking differential VGC $600.
Kombi 2x15x8 heavy duty rims powdercoated dark grey $220.
Kombi T4 EFI set up,microtech D4 computer with instruction manual,EFI intake manafolds,electronic dissy.$220.
Early 5 stud 2x15x8 rims $60.
Kombi instruction manuals, Operation and data booklet & driving-car care -do it yourself booklet in orignal grey plastic case. $20
Heat exchange S/S, oil to water, ideal for hot shower$20.
reinforcing plates ,weld on to spindle/ carrier $10 pair.
Gear box solid mount T2 box on to T1 frame horns $40.
Gear box rubber mount T2 to T1 frame horns $50.
Brisbane ,Manly
Ph 0424337151
James
bond ·
555bug may want these.
nick
sinecure ·
Adaptor plates,ford rear dics brakes to IRS T1 $20.
Will these fit a type3 IRS?
Midlife crisis ·
If these are still for sale i will take them..
Marc
0410920488
bushed ·
are the ford just disc brakes or also the studs for wheel and what pattern.
dibs them pending answer pls
kindly click my e-mail & send a a pic pls
B
James ·
The adaptor plate is a dounut peice of 6 mm metal [has not been drilled or tapped yet] which fits on the collar where the drum usuallly sits and on the inside of the ford caliper ,It will fit an T3 irs arm.
tdegens ·
James I will be coming around 6ish to have a look at the injection setup.
Cheers tom
