Water leak
https://forums.aussieveedubbers.com/threads/66008/water-leak
telf ·
does any one have this problem. When it rains the in side of the heater channel where the vent is (that warm your feet) becomes wet i have put a new front window seal in cos it was leaking and i thought it was that but it isnt, there is no other signs of holes that i can see it mainly happens on the left hand sidedose any one have any ideas it gets wet even when standing please help
Telf
mackaymanx ·
I have exactally the same problem, I have a small rust hole just forward of the vent which lets water in. If I have the door open and lightly spray water along where the guard meets the body I get water inside. I can't see anything but there must be a rust hole where the guard meets the body, I'll have to strip the guard off sometime in the future to find and repair this. This has been driving me crazy trying to find this.
Rust will be the problem
Rocket ·
Rust is one problem but also blocked drain pipes and leaking seal from body to vent tray.
telf ·
Thanks for the help
i am suprized i have any hair left i have looked every where for a rust hole i think im going to have to take the wing of ah well im sure if i dont find the source of this problem im sure ill find a new bigger one to fix
where is this bit (blocked drain pipes and leaking seal from body to vent tray
is it the air box under the dash if so the vent holes are blocked off
thanks Telf
Rocket ·
The box has a pipe that goes down the bulkhead and out of the car to drain water away
telf ·
thought that was the pipe thats blocked off from the inside ane the box has been removed for the time being so it cant be that.
Thanks For the advise though
think its wing off time
