PROBLEM - Burst Oil Filter
https://forums.aussieveedubbers.com/threads/66018/problem-burst-oil-filter
sewelly62 ·
Hi all
Seem to have an ongoing problem. Am running a fairly warm 2180 in a trike with a remote filter & oil cooler. Problem is intermittent and sometimes when i havent ridden it for 2 week or so when i start it up there is a wizzing sound (like a supercharger winding up) then the oil filter splits at the seam and dumps the engine contents on the garage floor.
Now i aint much of a mechanic but some of you will know the solution i have no doubt. Am i running too heavy an oil? Been using 20w 50. Using valvoline filter.
Any help will really be appreciated
Regards
Sewelly
if its a fresh motor then that oils to thick
i run 10/30 in all my new engines
i switch to 10/40 or 20/50 once they get abit older and worn
u may also have a stuck oil pressure releife valve too
u got an oil press gauge?
what brand filter are u using?
-Joel
ancientbugger ·
Also just check your crankcase vent tube. If that's buckled or blocked then the pressure can build up inside the case then the oil looks for the easiest way out.
Andy ·
What case are you running? Some will have a relief and a filter bypass. Either could be stuck as suggested above.
Also try a different brand filter. Not sure what remote filter you have, but Mahle filters are used a lot on Aussie VW's.
one4 ·
I had that problem during winter with cold starts.
The thickness of the oil meant it over pressurised the lines and blew out at the filter, which I was using nice strong Landcruzier filters.
So I dropped down to 10w40 no problems since.
PS There is now a nice line of line from where I worked across town to home. 🙂
Richard
koolkarmakombi ·
Done that myself on my ol kombi with Valvoline filters. No bypass valve in them and they are made badly- the stamped flutes inside dont open enough.
Use a decent filter. Golf Deisel filter has all the valves etc, get a wurth or other good one.
ive been using the purolator pure-ones
theyre double the price of a valvoline Z9 but theyre 10x better built
i used valvoline 4 a while and wasnt overly impressed by it
anyone ever tried a baldwin filter?
i can get them cheap from a supplier thro work, but they still end up pretty exy
-Joel
When I had VW or Audi motors that needed oil filters I always bought genuine brands such as Purolator, Knect, Mann Etc. Rycos and other filters are not as well made and don't filter as well.
I always buy a Genuine Toyota oil filters for my Prado, its a few extra bucks, but what's a motor worth.
sewelly62, you don't say where your oil exits the case. If its full flowed the oil is coming straight off the oil pump with no regulation at all, its asking for a line or filter to blow.
Adsman ·
DUB74L wrote:ive been using the purolator pure-ones
-Joel
Double the price for puroilator?? You need a new parts supplier. 🤪 Seriously. Puroilator are a good filter, Ive used them for many years. (Not on VW's though cause I dont have a filter)
just cheap skate auto
valvoline z9 $6.95
purolator p3001 = z9 $15.99
You need to check the releif valve
in the case...
pull them out and make surethey are free to move up and down...
Genuine oil filters are the Best insurance...
I don't use Valvoline filters either...
Purolator have a good name...
and best to use a filter with a releif valve too...
sewelly62 ·
Thaks everyone for your responses. Seems a fairly easy fix then. Lighter weight oil and better quality filter. Simple. This placef as always is a great resource and community.
Will let you know if the problem i solved tho i expect it now is
Regards
Sewelly
