Aussieveedubbers 路 Tech Talk
Air by pass screw - wont hold idle
https://forums.aussieveedubbers.com/threads/66097/air-by-pass-screw-wont-hold-idle
Bizarre 路
been having a bit of trouble holding idle lately
Tune the 34 pict
1 turn out air by pass
2.5 turns out for the mixture screw
After a days driving i have to heel toe to keep the idle up at lights.
Check the carb and the air by pass has bottomed out
re-tune and alls well
A day later it wont hold idle and the air by pass is bottomed out.
I have a lock on the engine lid so no one is fiddling.
The screw does feel "loose" and yes the O ring is there
Guessing it is a drop of Locktite 222
Anyone else had this problem????
Brian 路
Replace the O-ring ...馃槉
vw54 路
replace the O ring
and use a bit of Vasso or O ring lub and no dont use it down there although it does work LOL hehehehe
vw54 路
Opps 4 got while your doing one do the other as well
better of replacing both at the same time
kevo 路
whats the internals on the engine like? hopefully thats not the problem but lack of idle is one symptom
Bizarre 路
Nah - pretty sure it is the problem.
Stuch a blob of blue tac in the recess to hold the screw still and all is well.
Picked up a kit from CSC that has the 2 O rings.
Dave hasnt given back my KY yet so i will have to go to the chemist on Saturday
greedy53 路
replace o ring both
