Has anybody out there installed one of those new zero mile type 1 vw mexico factory long blocks you see advertised on the back page of VWMA. Are they OK or are they rubbish??
mackaymanx ·
Yes I had one in my Manx, just pulled it out today to go into my notch. I've had no trouble with it, it arrived with a bent mounting stud and a slightly dented oilcooler.
But I think it had been out of the box and then repacked without the proper padding then sent to me. Easily fixed but was a bit pissed off that I had to.
They have a cast crank and come without a distributor drive shaft. I've driven it from Mackay to Mt isa and Mackay to Townsville (x3) with no problems.
they're ok if you keep them stock..........
avwboy ·
have fitted two of them myself
one of them had a oil pressure problem , in the end the center drive shalf that sits in the cam gear was actually loose in the oil pump gear itself
second motor has been problem free
probably a isolated incident , as i have not heard of a second one
1916baja ·
I had one in my manx. I only got a year out of it before i had 2 burnt out valves. Everything was adjusted right they just wore out. But hey it never leaked a drop of oil! Mine didn't cope well when i put kadrons on it. Some people swear by them and some people swear about them! I may have just got a friday afternoon special.
Do these have hydraulic lifters???
nah dont think they do
just long reach plugs
everyone i speak to says there a good motor if u leave them stock
altho judys bug has one with extractors and a weber progressive and is going well
