selling stainless extractors
https://forums.aussieveedubbers.com/threads/66321/selling-stainless-extractors
westi ·
hi all,
i have 4 sets of 4 into 1 stainless steel extractors for sale.
these are made out of 1' 5/8 304 grade stainless.
they are only $199 each.
if anyone is interested i can ship anywhere.
you can u2u or ring beau or brad on (02) 9773 7244.
i have included a pic from a set we put on a mates car,the ones that you are looking at have been shortend alittle .
Gracey ·
Awsome price! Does that include the muffler?
Any plans to do a sidewinder version?
westi ·
some time after x -mas i am going to do a few diferent styles of exhaust to go with the extractors .But for now just extractors.
westi ·
here is a few more pics.
reub ·
Looks Awesome!
What is the price for a complete setup as in the photo - i.e. with resonator and muffler?
westi ·
with everything fitted $800.
i will be jigging some up after x-mas and it should work out to about $500 to supply the whole system.
11CAB ·
Very nice looking system. Must be a pain doing the tappets for 1&2 though.
reub ·
hmmm....thanks Westi.
Good to talk with Beau the other day too...sounds like another nut. I understand he's one to wind you up a little too, and also had a tough 1916 a little while back. Good stuff👍
westi ·
as for the tappets you just unbolt the muffler.takes five minutes on the ground.
hey ruby whats you 1916 combo.
it is easy to wind each other up when you are a little car crazy.
Quoll ·
Hey westi can you make up other kinds of systems?
reub ·
westi wrote:as for the tappets you just unbolt the muffler.takes five minutes on the ground.
Combo as follows...
Fully flowed and clearanced RIMCO case
CB performance MAXI 3 full flow pump - blueprinted
CB performance lightweight lifters
Scat 1.25:1 4340 pro comp ratio rockers
CB performance 2242 camshaft (294 intake duration)
CB performance Magnum 8640 chromoly straight cut gear set
New Steve Timms ported and cc'd 043 heads, 40x35 valves, ported, chromoly retainers, stainless valves, dual springs (to run 8:1 static compression)
Match ported intake manifolds
CB 69mm welded crankshaft with 8 dowels, balanced
Scat 4340 chromoly I beam rods with ARP bolts
12lb german forged flywheel, 8 dowelled.
Gene berg deep sump extension (1.5 lt extra oil approx)
Aircooled net 6160 alloy pushrods
New Mahle A's P&B that have been balanced
1 5/8 hpc coated merged slip fit header
Black fatboy (for initial use - custom one to be fabricated)
Bosch 009 with compufire module
MSD 6AL ignition and MSD blaster 2 coil
Scat billet serpantine pulley kit
mat54 ·
hi there
do you think it would be possible to make a set up that would exit the stock cutouts
going to run a strong 1916 but want to keep stock appearance as the rest is stock-ratty.....
and dont want the exhaust to restrict all thedollars going into the engine....😎
steffen
broms ·
I'd be interested in one of those too!
westi ·
we can make anything.Quoll
for the other guy's do mean something like this.
broms ·
Perfect, exactly what I am after!
What does something like that cost?
Dero ·
Aussie Performance parts!! SWEET. That is some real nice work there...
westi ·
that one was $900.
1SlowBeetle ·
I like your work. I was going to get a fitter and turner I know to put together a set like this for my 1916, but if you have all the jigs and kit already, there isn't much point.
The first set you showed are what I am after. any chance of getting a pic of this system on a car on the ground. I love the shots from under, but lets face it. I'm the only one who will see it from there.
Also, what would it cost to have a full set up sent to Canberra.
Cheers...
Type3Sicko ·
any of these left?
