EJ22 Oil Leak
https://forums.aussieveedubbers.com/threads/66390/ej22-oil-leak
mattie182 ·
Hi all,
I have completed the EJ22 in my buggy, and the most things sorted except that oil is coming out my air filter❗
If on a short run, things go great, but whenever I seem to drive it down the highway, for a longer period, oil gets sucked up the breather pipes and dumped out the air filter.
I have just replaced the PCV valve, and it is stil doing it, what else could it be??
Matt
OZ Towdster ·
How have you got it plumbed
rocknrob ·
Hey Mattie stick a couple of these on🤘 at least if you are blowing oil it will be with a bit of bling😂
[/img]
mattie182 ·
From the top of the crank to the intake (biggest hose)
The two tappet covers joined together, then up to the intake. The other hose, isplumbed into the "tappe cover" hose.
I think, im at work and trying to do thsi from memory
Will check tonight and take a photo
Matt
MickH ·
Photos would be nice.....👍
subisupa ·
I had a look at mats car, seems to be coming up out of the crank breather. Which tells me that the case is being presurised which can be caused by rings gone. Any other ideas as to why the crank is pressuriseing?
We might put a compression tester on the old girl I think
Brad ·
if you have the lines wrong them you will pump presure into your own sump.
- Remove the hoses to your tapet cover and go for a drive, see what happens
- You need to keep your case plumbed down stream of your AFM and have your oil cap on tight. Tappet covers are just emmision crap and can be bypassed.
- EJ's run quite a bit of crank presure stock, pull ya oil cap off and watch it die ....
Take some pics
