Aussieveedubbers 路 Tech Talk
gearshift linkage bolt??
https://forums.aussieveedubbers.com/threads/66472/gearshift-linkage-bolt
lulu94 路
how do I get the damned thing out??
type 3 with IRS, trying to remove motor and box, but the hardest part is getting the damned gear linkage off.
it seems to be an 8mm square headed bolt, so I cant even use any of my good sockets on the bloody thing.
anyone got suggestions, an oxy or similar is fairly much out of the question.
oh and its Ryan BTW not Danielle shes just logged in.
Baja Wes 路
They normally aren't tight, so a spanner or shifter will do the trick. Just remember to remove the safety wire first 馃檪
13bwagon 路
yeah use an open ender that fit and make sure the wire is cut off
lulu94 路
hmm, we must have a tight one for some reason, pulled the lockwire off, and turning as hard as I can with an open ended spanner (being careful not to let it slip arond and ruin it all)
I gave it a good soak with WD so with a little luck it will come undone tomorrow with a bigger shifter.
Baja Wes 路
hit it on the head with a hammer a few times, if it doesn't help loosen any rust holding it in then at least it will make you feel better 馃檪
lulu94 路
that sounds real good in theory wes, problem is, once I hit it, the head will probably get damaged and the bloody thing will never come out. and its not actually rusty, its fairly greasy looking in there.
hellbugged 路
vice grips if it it gets damaged
vw54 路
use a 3/8 inch extension and use the female end on the head of the square drive to undo it u can use a spanner or shifter on the male end EASY
lulu94 路
vw54 wrote:use a 3/8 inch extension and use the female end on the head of the square drive to undo it u can use a spanner or shifter on the male end EASY
3/8 would have been much too big, tried to think of anything with a 5/16 or 8mm internal square I could use, but no luck.
ended up getting it out with a big pair of vise grips clamped onto the head, then a shifter onto the vise grips to turn. once it was cracked, it came out easily by hand.
greedy53 路
heat it with a plumbers torch than dump cold water on that will snap all rust and break it free from whatever is holding it
