I am in need of and electrician who can rewire an oval for me, i did the stupid thing of tearing out all the wiring and now need to redo it all. If anyone can help or knows of anyone that can help plz let me know.
Cheers Zee
blutopless2 ·
i take it you wrecked the wiring when you removed it??
BU90FF wrote:Hey peoples,
Cheers Zee
You are Lucky, as the wiring in an oval is minimal...
and easy for anyone with knowledge of VW wiring..
I ended up having a go at rewiring the car myself, not as difficult as i thought but still a BIG PAIN in the bum.
I was wondering if anyone knows how i can test that all is ok without an engine as i don't have one in at the moment.
Is there a way of running it straight off the battery or will it work the way it is if i plug the battery in.
any help or tips would be much appreciated.
Cheers Zee
Merry Christmas and a happy new year
silver ·
Where in Sydney are you?
BU90FF ·
i am located in Arncliffe 5mins from the airport
Are you on Wollongong road? Seen a 2 tone bug getting built plus a Oval in that area.
Just hook up a battery to the system and then plug a test light into the circuits you need to test. Don't use a multi meter, you need the resistance that a test light produces for proper testing.
BU90FF ·
1303Steve wrote:Hi
Hey steve,
Cheers for the tip so far everything seems ok.
As for the bugs, yes the oval is mine and the two tone belonged to a friend across the road, he moved to tassy and took the thing with him.
See yas
57oval ·
Do you still need a hand?
BU90FF ·
57oval wrote:Do you still need a hand?
Thanks for the offer!
I had a go at it and just finished testing everything. Seems like it is all working so far. Still trying to make the semaphores and indicators work off the same switch, i think i figured it out, im trying to have the semaphores stay up while the blinkers are on.
I will have a crack at it tomorrow. too tired.
Once again thanks for the offer, much appreciated.
Cheers zee
mackaymanx ·
I wired a morris minor so the semaphores stayed up while the blinkers were on, I think I used two relays to make it work. I can't remember the details as it was about 25 years ago.
BU90FF ·
yeah, i am going to use 2 relays. i think its the only way
57oval ·
You can run the semaphores off the indicator stalk and use the same two wires Black/green & black/white and use two indicator relays to run your other lights. I can also modify semaphores so they can flash with the rest of your lights.
BU90FF ·
that sounds like something worth looking into! would you need to run separate power to the light and a separate line to the semaphore itself?
57oval ·
BU90FF wrote:that sounds like something worth looking into! would you need to run separate power to the light and a separate line to the semaphore itself?
You use existing wiring to semphore, when you look at the wiring inside the semaphore you will find ther are to wires soldered together at the top screw terminal. Carefully remove wire from terminal, take off the grey sleave and you will notice two wires soldered together. One is for the coil the other to the light. I put the wire for the light on the lower terminal and the coil wire back to the top terminal. Make sure you insulate the tab which makes cotact with the pin that makes cotact with it when fully open. Know at your speedo remove the indicator light which will have two blue wires conected , run them to your separate indicator relays for your semaphores to flash. If this is to difficult for you, i can modify them for you .
