removing axels from trans
https://forums.aussieveedubbers.com/threads/66580/removing-axels-from-trans
Learner ·
how do i get the axels out of the trans? i'm trying to replace my trans
any help would be great.
thanx
swing axle or CV joints ??? what year model
Learner ·
yeah sorry it's a swing axle and a 1969 model cheers
its easier to do with the gearbox out of the car
So remove the brakes and backing plate and breaing retainer
remove the rubber axle boot cover near the gearbox
undo the 6 x 13mm nuts holding the axle cover to the gearbox
u need a larger set of cirlip pliers to remove the inner circlip
once this is off they should slide off
u may need a bearing puller as well for the outter wheel bearing
hope this helps
hope this helps
hope this helps
hellbugged ·
vw54 wrote:its easier to do with the gearbox out of the car
hope this helps
just to save you the trouble again Dave😂
yeah my putor was slow so i entered 3 times 😵😵😵
Learner ·
haha thnx that's the one thing that kept me from going any further
