Aussieveedubbers 路 Tech Talk
White wall inserts Vs painting
https://forums.aussieveedubbers.com/threads/66599/white-wall-inserts-vs-painting
aintgotitmusthaveit 路
Hi guys,
Got some dunlop 300Es for the replica to see if I can get it to brake a bit better but they are jnot white walled!
Q. Also have a set of white wall inserts that I have never used. The rubber ones that fit along side the tyre...
Has anyone used them?
Feedabck good bad?
I have heard ther don't allow the tyre to seat properly and therefore they leak!
Else how much to paint a white ring on them and who does it in Melbourne?
phatratpat 路
daily driver or weekend show pony?
had the flappers on my daily driver
they never leaked but they did wear
into the side wall of the tyre !........馃檯
greedy53 路
yep no worries with tyer sealing but if the profile is to low they will get a real beating as they will tap the road when cornering i know
screwed a goodd set before i found out the problem 65-75 series work great
Craig Torrens 路
I have the flappers on two cars, no probs.
65busser 路
Flappers or inserts can be a nuisance as mentioned if you've got a lowish profile tyre. No probs on some. Dennis 0414986263 does etched 3/4" whitewalls which are pretty much trouble free. $100 or so. They'd look great on that. Period correct for a 60's car. Go for it!!
Thanks guys,
The tyres are 195/65/15 fittingon the 356 mangels.
I will see how they go ( and carry a pump by the sounds of it!)
