Wanted. 1971 Super Beetle ignition switch.
https://forums.aussieveedubbers.com/threads/66623/wanted-1971-super-beetle-ignition-switch
I have the key and barrel, it is the switch mechanism at the back that has the problem. It is worn out, but not burnt out. It is a specific type of switch as it is a die cast housing unit. The later ones are plastic switches, and there are different one s with steering locks.
Just to clarify, it is the die cast metal switch mechanism I need. It will have a fair bit of wiring attached as the wiring is soldered to the back of the switch. It is held into the back of the ignition barrel by a small grub screw..
Anyway if anyone has one, please PM me. Our beetle is off the road for two weeks now, and any help would be appreciated.
Pete
I believe that the same switch also fits 71-74 Bay windows as well. I guess you have tried the usual suspects for one? Try Aircooled.net, they have them for $34.95 US.
Or you could convert the column to a 72 model and get the wipers on column.
give Vintage in Sydney 02-9789-1777
bushed ·
i got one with wires attached
whre s yer garage email me if interested
Vw nutter ·
yeah i got one here too, its pretty OG and made by z germans id let it go for $499 since its pretty rare u c.
