NEED HELP!!!! Geneberg Shifter Removal
https://forums.aussieveedubbers.com/threads/66629/need-help-geneberg-shifter-removal
Pete ·
Can Anyone give me any information with regards to the removal of a geneberg shifter? It is a lockable key version and i have tried every which way to try and remove it out of a customers car. I would rather not break it as they are worth over $350, Any info would be appreciated
Peter
dangerous ·
From memory there is a cap screw, that you shear off on installation, in the base.
I think it faces the front of the car...or does it face rear.
Anyhow, you will most likely have to drill it out.
If it is tough, use a concrete drill(tungsten tip) and sharpen it up for cutting metal.
greedy53 ·
you can also if u have a small air cutter wheel cut aslot in it and use a screwdriver eather way you got work to do
Pete ·
thanks guys sounds like i have a day of fun ahead of me!!!
pod ·
use a cobalt drill and start small then go to the bigger size,use a slower speed with plenty of lube,tungsten tip drills will usually just smash to peices or the tips will fall off with the heat as they are only brazed on👍
Brad ·
there is a grub screw in the front and back, unlock the unit and then remove them both and the top will lift off. Don't cut, drill or grind anything ......
