just a quick one...
https://forums.aussieveedubbers.com/threads/66664/just-a-quick-one
n4t4l1e 路
Just at the stages of painting
So far the process
De-ox
Etch prime
Epoxy prime
Then...
I can only smooth, sand and fill (if needed) ontop of the epoxy? Hence why I use the epoxy as etch is stickier and you can't sand or put bog ontop of this?
Is this correct?
Just wasn't sure about etching and epoxying and why I should do both.
Thanks in advance
Nat
x
n4t4l1e 路
? Nothing? 馃檨
type3kid 路
i am replying to bump your thread so you can get an answer. i have no idea so right now i'm as useless as boobs on a bull!! hope the bump helps.馃お
matberry 路
The bump did help.
You need the etch to properly bind to the metal, then the epoxy primer provides a substrate that your fillers and paints will adhere to. (Make sure all your products are compatible) I would even recommend sticking with one brand these days for this reason.
I was told this just days ago by the BRS rep, whom I have known for 25 years, he has just become a paint rep after owning/running/working in a panel shop since before I met him. (get the idea, he has lots of expierience)
5PL1TDCS10N 路
Body filler needs to be done on bare metal but if you just want to straighten a panel then a hi-build primer will suffice. Make sure you have the correct gun setup for shooting primers(1.8-2.0 tip). Paint is usually 1.4. This is all depending on what brand so get a tech sheet from the paint rep. I also recomm. using a complete paint system(everything from one brand or as recomm. by paint store)
This is how I personally do it but I am self taught. Helbus and Alan(Dasdubber)know alot more.
1: Baremetal- Do rust repair.
2: Treat with Rust Convertor. Leave for a day or two. Then clean surface throughly.
3: Spot repair big repairs w body filler
3: Epoxy Etch Primer
4: High Build Primer
5: Primer Surfacer(which usually is a thinned down version of step 4)
6: Guide coat-sand and repeat step 4 or 5 if ness.
7: Base coat
8: Clear coat
This is a very very rough guide btw so hope it helps-Wayne馃檪
matberry 路
matberry wrote:The bump did help.
I should have then said, anyone with more trade expierence please correct me if required.
n4t4l1e 路
Firstly thank you for the bump
And for the info supplied! Fantastic help! 馃檪
Will crack on soon and see how I go, will no doubt be back! As I'm grinding and welding at the moment :S
Thanks heaps peeps 馃榾
Nat
x
helbus 路
matberry has it pretty right. We do mostly $100K plus resto's at my work, and we do
- Bare metal by abrasive blasting
- All metal repairs, rust, lead wiping etc.
- Secondary abrasive blast, as sometime 2-3 months of metal repairs means surface rust again.
- Etch prime
- 2 Part epoxy
- Filler
- Prime
- Putty
- Prime
- Paint
Usually the body is fully rubbed down about 20 times along the way with various grits of sandpaper.
n4t4l1e 路
ace thanks hell bus.
Loads of help and really appreciate it
Nat
x
