sig erson rocker adjuster needed
https://forums.aussieveedubbers.com/threads/66882/sig-erson-rocker-adjuster-needed
lohoon ·
I have just put another motor in a 68 Baja after dropping a valve.Was installing the 1.4:1 ratio rockers when i found a broken adjuster.These are a little diffrent to usual vw type ones as they adjust on the pusrod side not the valve side.They also have a allen head not a flat screwdriver adjustment.
Any leads would be greatly appriecated.
Scott
dangerous ·
I recall "performance warehouse" in Melbourne was a distributor for erson products
and the adjusters are common for V8 products.
They used to sell the VW kits and advertised in VW power magazine all those years ago(it was the eighties)
If no luck I think old Chrysler V8 adjuster may fit.(273 to 318ci )
hellbugged ·
same as bergs, i have a few spare............or try vintage vee dub
lohoon ·
Thanks Guys.I'll do some ringing around and see what i can come up with.
dangerous ·
dumone wrote:same as bergs, i have a few spare............or try vintage vee dub
From memory the Erson rockers came with a male ball on the adjuster
and a femail cup n the pushrod.
hellbugged ·
ooorkay D.B
anyway if they're like these and you need one to keep you going, let me know
lohoon ·
yeah Daimo's the man wit the gear.....again.Thats them.I just got back from a hour drive,2 hour talk shit to have a look under the rocker cover of 318 i knew was sitting for a while to find............HYDROLIC LIFTERS!!!
No adjustment on them suckers!
If you just need the one adjuster and there the same as the pic above
Vintage has them available 02-9789-1777
dangerous ·
http://images.thesamba.com/vw/classifieds/pix/1592383.jpg
That is good to know that they have been updated, at least it will be easier to get a new one.
lohoon ·
Mine dont have the ball like them ones Dave.Similar to Damos picture.Same adjusters as Damos picture.
Many thanks to all who gave advice and time.👍
thats the standard Berg type with the socket
I know there are a few at Vintage
