Hi All,
I have a pair of 73 Type 3 front brakes.
These were only fitted to the last of the Type 3's they are a larger diameter disc and larger caliper.
I have a pair of the front stub axles, 4 calipers, a pair of secondhand discs with plenty of life in them, a pair of matching backing plates.
I also have a set of caliper kits to rebuld at least a pair of calipers from the 4 included, I also have a new set of brake pads to suit in the box never fitted.
These brakes can be bolted straight onto any model type 3, or you can modify Beetle front stub axles to take the larger discs and calipers to give your VW a better braking system. You cannot fit the Type 3 stub axles directly to a Beetle.
$250 the lot, not really intertested in seperating.
I have pics, but for some reason they will not post up here, if you want pics, PM me or call and I will send them to you, unless a moderator wants to post them up for me.
David
Calcool ·
