BIG engine build up
https://forums.aussieveedubbers.com/threads/66988/big-engine-build-up
Golde60 ·
I have already asked a few questions of Dangerous Dave and Ian 2443 (he of the big turbo engines).
Thanks to those guys for the advise already.
I am looking at a long term project engine which I am starting the research process for and hope to build myself.
Will be replacing a 2L t4 in my 60 ragtop.
Goals are:
old school looking engine bay (in particular, na, 48 or possibly 51 idas)
different combo (hoping for around 2.5L)
streetable, but only a weekend warrior with ability to do the odd 2-3hour trip and traffic jams. Plenty of joyrides and drags
hoping to get into the 12s with full weight
gearbox to suit (likely berg 5 or 915 conversion)
So with this in mind, I have decided that I will wait for the TF-1 case to be built.
I like the clearance for bigger than normal strokes, and also like the 0.100 dropped cam.
I want it to work on a t1 based head, have the cb cnc ultra wedge port in my sights at the moment.
I also like CB's JayCee 51mm ida they look like good value.
I need some advise about the combo options that I have.
I had all but decided on a custom 90mm berg crank (custom order), and flywheel to match
However, since reading some comments regarding the available alternatives I have some questions.
What are the benefits/pitfalls of wedgemating vs flanging. I am thinking that wedgemate will be enough.
As such I am looking at cranks such as DMS and DPR rather than Scat.
Also, does anyone use rods larger than 5.7?
I can really only find the carrillos as an option, but with a 90mm stroke I think I will need larger than 5.7.
Also, does anyone know if I have options larger than 94mm cylinders?
Have been looking at nickies, but their best is 94mm.
Please feel free to throw as many ideas and criticism at me as possible, as I said I am starting the research stage and looking for all the help I can get.
What do you think?
94 mm is about as big as you can go on a stock case set up
56astro ·
He's not using a stock case Dave.
He's decided on a TF-1 case.
http://www.precisionalloy.com/index.html
Golde60 ·
yeah, thats right steve.
I was thinking some of the 96mm cylinders that Jake and the t4 boys all recommend on the stf
dangerous ·
Bergs did "practial application development" with their "lab" (black car) about 14 years ago using the 95mm porsche piston and cylinder.
They were very happy with the performance and longevity in that combo, and believed it to be worth while.(except for cost)
Since then, an off the shelf kit is available from LN engineering in the USA
Brian ·
Even 94's are too big 4 a type 1 , you can't use any bigger and expect it to work , it won't. 96 mm is just OK for a T4 not T1.
dangerous ·
Here we go......
Brian wrote:Even 94's are too big 4 a type 1 , you can't use any bigger and expect it to work , it won't. 96 mm is just OK for a T4 not T1.
..and where did that you glean that pearl of wisdom?
nbturbo ·
dangerous wrote:Here we go......
----There would have to be a Woman out there somewhere that gets that humour-I got a laugh from it.(thats from your tinkering post)
Golde60 ·
ha ha
thanks for the LOL dave
I think I have just about been convinced on the 95's
If they run 105.7's on a 3.0 t4 (Jake Raby's) that have a similar wall thickness then I will be ok.
Not in any hurry though, so will wait for him to do some more testing as promised. He will be trying them out on one of his 'test/r&d engines'
On another note, what about rod ratios?
If I use a 90mm stroke, will 5.7 rods be big enough?
I dont think I m gonna need much help with the torque, but rather the top end, so am thinking that I might need a longer rod
dangerous ·
Only a MUCH longer rod will have any measurable effect.
I doubt you would even feel it.
With those heads you will not lack anything anywhere.
Your priority will be to make it fit in the engine bay, and for this reason a 5.6 or 5.7 would be my choice.
I have used 5.5 with 90 stroke and the main hassle was the piston clearancing at BDC.
Thus my suggestion of 5.6 or 5.7.
400 chevs used 5.57 with 95.25 stroke and longevity was perfectly adequate
Even the 350 had 5.7 with 89 stroke.
There is a common misconception that rod length controls the power delivery or curve,
when in fact this is more a relationship of engine size, and cylinder head capability.
Camshaft will be a factor.
Rod length when combined with cam shaft can influence these things,
but more along the lines of optimising a particular engine and cylinder head combination.
This also applies to exhaust and intake lengths.
hellbugged ·
dangerous wrote:Bergs did "practial application development" with their "lab" (black car) about 14 years ago using the 95mm porsche piston and cylinder.
still using the 95mm to date..........i think Dee's street car is running them nowadays too
yeah and the Earth is also flat.
2443TT ·
I noticed that nobody talked about flanged cranks vs wedgemated. This was one of my challanges because i am going to need a lot of clutch for my new engine.
Modern chromoly cranks with 8 dowell and a large chromoly 1 7/8th gland nut will safely hold around 240hp, though i think id still be nervous about doing this with slicks on the car (especially since ive never driven on slicks). I had easily that power with the 2332 turbo engine.
Wedgemate will hold all the power that an NA engine can throw at it. The advantage is that you still have steel shims to help carry the load of having the flywheel running hard against the thrust surface on the number 1 bearing. When your foot is on the clutch the force of your pressure plate pushing back against your foot is also being pressed against the surface of your main bearing. The disadvantage is that wedgemate doesnt last for ever, so if its a race engine that gets torn down regulary it might need to have the wedgemate freshened up occasionally. Aircooled.net have a great puller tool that bolts onto the outer clutch bolts and exerts pressure on the back of a loosened gland nut to allow easy removal of the flywheel. You could make one of these easily enough.
Flange will never break due to traction at the tyre resulting in the flywheel twisting off the engine. The problem with flanged is that the number 1 bearing carries the full load of the pressure plate at full RPM. Where as stock and wedgemate will allow the shims to spin on eachother a little, reducing the load on the bearings thrust surface. Aparently the problem is the bearing heats up, expands and then locks onto the crankshaft. More end float helps with this which is why the flanged drag engines run upwards of 0.012" end float. But they are also running stage 3 clutches and 4 pucks. To reduce that pressure on the thrust the only option I could see was switching to a twin plate and running a lower tension pressure plate. This reduces load on the bearing. Also thanks to dave's advice i've had all the mains teflon coated, so they will be more slippery, thus reducing heat.
About rods, i saw 6" rods on a roller crank on the samba for sale once... but finding a set easily with the bolts going downwards to the end caps instead of from the bottom like chevy's will be a challange. Like Dave said, trying to keep the engine narrow enough to get it in the engine bay will be the challange. I ran 5.325" rods on the 84mm crank in my last engine and had to clearance the piston skirts. This allowed the engine to be narrower than most strokers and still fit with just a little clearancing. As that engine ran a fair amount of deck height (6.5mm from memory) it was still wider than stock.
I've been looking at the 2.1lt T5 engine case again myself... if only I could fine an engine around to trial fit an 88mm crank too. I really think thats a direction to go in, because 103mm bores just slip on, 10mm head studs no problem, T1 lifter conversion not a problem... and everything else T1 just bolts on. Also its got to be considerably stronger than the cast alloy cases of today, just becasue VW made it. No porosity from sand casting.
Golde60 ·
Yeah, still looking at all the options, especially when trying to work out a combo that will be what I want once its finished.
That is my challenge at the moment, cos not many strokes bigger than 84mm out there on street engines.
I have looked at the t5 again, and still thinking about that.
I looking very closely at the t4 again, but a whole new project engine, not an upgrade of the existing one.
I can go bigger a bit easier once i ditch the t1 stud spacing, but the heads are difficult to find/pricey.
Has anyone had any experience with Jake Raby's kits. There is a 2.6L diy setup that I discovered last night......
Das and 66deluxe spring to mind.... any others out there?
2443TT ·
Unless you have the crank already, a T5 with 103mm barrels will give you some huge displacement if built on a 2.1lt engine case. It will rev better too due to the smaller stroke. You can buy CB comp eliminators in an un-drilled form, get them machined and drilled for the autocraft spacing. Then head cooling can be an issue i suppose but water jacketing might be an option for you too.
Raby's stuff is hard core! I like the remelle T4 heads too. The look like comp eliminators but wity WAY more cooling and Type 1 exhaust ports. They are making 280PS 3lt engines on a T4 case.
2443TT ·
http://www.remmele-motorsport.com/en/index_aircooled_en.html
66deluxe ·
Remmele does have some awesome engines and heads but last i heard he is very hard to deal with, people have been waiting over 12 months for parts ordered and payed for. There is also engine plus in Germany who make an even better type 4 cylinder head. Good luck in your endeavor Golde.
mactaylor ·
Engine plus got a web site?
Golde60 ·
yeah, I got some links at home, will post em up later for those that are interested.
Have looked at all these, and I am starting to like the 2.6L kits for the proven combo and Jake seems to have a good rep.
Golde60 ·
here is a link to some engine pluse pictures on stf
http://www.shoptalkforums.com/viewtopic.php?t=68053
also, here is there website
http://www.engineplus.de/pages/en/zylinder_koepfe_bilder.html
gwd have some different heads, more t4 related though
http://www.gwd-weiser.de/index2.htm
here is another website with some cool looking stuff
pretty pricey though, with the Euro being so strong
http://griebel.blogspot.com/search?q=JPM
Golde60 ·
I met a guy from the stf yesterday, Frallan (Fred) who was very helpful and has an awesome vw dragracing and modifying history. Made me look like a bit of a novice really. Anyway he was most helpful and really talked me into the t4 for a big displacement engine.
So I am leaning towards a Jake Raby kit, they seem like the most honest one out there, and I look forward to talking some with him over the next few months.
Now just to convince the wife.......
johny rotten ·
Raby is a very good salesman,
Everything in America is bigger and better!
Even that cooling system he sells , as a BETTER than Dr Porche design !
No independant testing, just his own .
Just my 2 bobs worth
I would prefer a type 1 or as has been suggested a WBX.
The WBX case is far superior to those crappy castings made for type 1 from who knows what material.
Most type 4 casings are well past the use by date
The type 4 heads are crap , even Raby can't deny that , the type 4 has a strong basis for a forced induction set up, but for normal aspiration they just don,t spin up like a type 1 or WBX and they cost a shitload.
Dasdubber ·
Here is a post on cal-look forum re. larger bores (101.6) in this case in comp eliminators.....just FYI.
http://www.cal-look.com/forum/index.html - bugger, for some reason I can't post the direct link to the thread - just go to the drag racing board and look for the thread title "101.6mm bore CB Comp Eliminator!"
As mentioned above Jake Raby is a great salesman but also I do acknowledge the time, effort and money he puts into R&D - until someone else steps up to the plate to independently critique cooling systems, and other parts, we're limited to what published information there is available (ie. from RAT). Having spent 6 years study in science and years in research, I know the importance of effectively controlled studies/trials.....here is hoping someone will follow his lead and do some research of their own rather than just publishing opinions. It is certainly what will help to keep our 'hobby' moving forwards and stamping out some of the crap parts we have endured in recent years.
Good luck Kim - engine plans sound great -I look forward to watching your progress.
Alan
2443TT ·
Out of interest its just under $2000 USD for a fully modified Rocky Jennings engine case delivered to Australia. The case second hand is $250 and the rest is machining and materials. Thats lifter bore converison, barrel sleaves for 94mm bore, clearancing for large stroker crank, oil system mods, raceware main studs, water jacket machining, and head stud conversion, plus in my case a full set of custom made bearings to accommodate a Type 1 flanged crank with T4 center mains.
Golde60 ·
sounds like that is a change of plans for you ian......
I dont think that will suit me. I have to be more realistic about my circustances over here and think of something that I will actually finish with limited tools and space.
sounds good tho
2443TT ·
Yes im now going oxy boxer.
I think that in your case though to make it really worth your while if you were to build one you'd have to do it with autocraft heads as well, so you can really crank that displacement up there without adding a lot of extra stroke to the engine and allow it to be air cooled as well. That would mean an easy 6500-7000 USD before you start getting internals. Could be opening a money pit...
dangerous ·
Dasdubber wrote:Here is a post on cal-look forum re. larger bores (101.6) in this case in comp eliminators.....just FYI.
I just"open link in a new window" when I select a topic on Cal-look,
that way you can copy and paste it no wuckers.
http://www.cal-look.com/forum/index.php?topic=24043.0
Dasdubber ·
Ahhh.....you're not just good at making muffins and building gearboxes hey Dave!!
dangerous ·
Dasdubber wrote:Ahhh.....you're not just good at making muffins and building gearboxes hey Dave!!
I am also very good at sex.
dangerous ·
I come first every time!
Now, back to your scheduled program....
66deluxe ·
dangerous wrote:I come first every time!
Funny Bastard😂 you spose to say you ran a marathon last night with the missus and come last.
mactaylor ·
when you share info dave you really do not hold back do you!!!!!
golde why dont you look at going a s/h auto craft or simmillar case with all the good bits doesnt end up that much more than a played with autolinear jobbie.
Brian ·
2443TT wrote:Out of interest its just under $2000 USD for a fully modified Rocky Jennings engine case delivered to Australia. The case second hand is $250 and the rest is machining and materials. Thats lifter bore converison, barrel sleaves for 94mm bore, clearancing for large stroker crank, oil system mods, raceware main studs, water jacket machining, and head stud conversion, plus in
Why not just get it machined locally?
its not rocket science
Golde60 ·
LOL
here we go again.......
2443TT ·
Thats easy!
I've been burnt too many times by local work thats done to a 1/2 hearted, she'll be right, its good enough cause its only for a VW standard that I get from australian shops. I guess thats because a lot of vw people dont have a lot of money to throw at their cars so a lot of corners are cut all the time.
Being in Cairns I dont have the capability to closely monitor what a machine shop down south is actually doing for me, not even investigate what their real capabilities are. There is no guarantee that they will get it right the first time. Having had to freight parts all round the countryside before im not willing to go down that path at all again.
For me its more important to get the job done right the first time. Rocky Jennings is making an engine case guaranteed to hold 500hp with reliability. I doubt there's many shops in the country that could make that same claim.
66deluxe ·
Well said Ian, and not too many shops here care either, Rocky Jennings is the man for this also, the only website pertaining to this machine work is his, i would love an oxy boxer one day.
