Aussieveedubbers 路 Buying, Selling & Swapping Parts
TURBO & WASTEGATE
https://forums.aussieveedubbers.com/threads/67046/turbo-wastegate
JVLRacing 路
TDO5 with WASTEGATE
Turbo is flowed and the external wastegate is modded
I have a Intercooler to go with and a Silicon Hose.
Thinking outside the square this turbo should fit most VW application with some thinking.馃憤
I will throw in a 3inch ceramic dump.
This Turbo was running 300hps at 13.5psi
The lot $650 firm 0409125965 John ..Coffs
seagull 路
what is the inlet & outlet wheel sized John ?
are you saying you have welded the waste gate closed ?
JVLRacing 路
Hi seagull, no the wastegate is not welded.The prob i found is the gateway doesnt open wide enough(more adjustment to activater arm)
Turbo wheel is around 43mm( i have to check) with housing smoothed internally. I had another tdo5 on it and nether got close to this one in flow馃檯
JVLRacing 路
Cheap
