Advice on Mechanic to use Brisbane Woolowin
https://forums.aussieveedubbers.com/threads/67120/advice-on-mechanic-to-use-brisbane-woolowin
tdegens ·
Hello,
It is time for the Fuel injection to be removed and Carburettors put on. Who is best to use near woolowin? I will supply the carbs and linkages. Any Ideas.
Thanks TOM
bond ·
german auto - lawrence at zillmere.
or
custom veedub - pete at stafford.
nick
butidontunderstand ·
happen to know of any ways to get a kombi to either of those places? its not going so is currently stuck at my house...and i know nothing about kombis
Brad ·
where is Wooloowin ?
Brad ·
Ignore that I looked it up.
I have used Pete the tow truck driver heaps and am very happy with both his service and his rates. His number is 0412268087 he he knows how to get to Custom Vee Dub - 28 Hayward St, STAFFORD
Andy ·
Are you serious? Why go away from EFI?
Get it running right and it's better than carbs.
Their's a fair bit of work in swapping it out, all the extra lines/hoses need for the EFI plugging off or removing. You also need a new fuel pump, dizzy, air cleaner, hoses, fuel line, power cables etc. Even the tin ware on the motor is different, but probably does not need replacing.
I'll give you a hand to do the change in swap for all the EFI gear 😵‍💫
Keep the EFI. If it needs some repairs, repair it! It'll no doubt be cheaper and certainly very reliable.
toplessbug ·
Why???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
do NOT get rid of efi just because you have an issue right now ,learn about it and fix it its so much better than carbs,
