I've developed a leak somewhere in the brake system but unfortunately I didnt check my reservoir level frequently so have no idea if the leak is a gusher or a trickle so im attempting to flush the system through and keep a careful eye on the levels.
Its a '71 type 3, front disks, rear drums.
Im having troubles bleeding the rear brakes. I've done the front calipers ok - does it matter if i bleed these before doing the rear wheels? Anyway, it seems one of the rear bleed nuts is leaking air back in even though i only loosened it a fraction, so using a tube into a jar of fluid isnt working. Is there any way to get around this?
brisbanefastback ·
