Clearancing bell housing on a 6v gearbox to suit 12v flywheel
https://forums.aussieveedubbers.com/threads/67136/clearancing-bell-housing-on-a-6v-gearbox-to-suit-12v-flywheel
Ian Bugden ·
Hi all,
I do not know if this has been covered before but I am after any info in regards to where I have to grind the bellhousing inorder to suit a 12v flywheel. I do not yet have the flywheel so i can't throw in on the output shaft and see. I did however put the 6v one on and can't really see where to clearance.
It is a type 1 6v tranny.
Cheers for any help (pictures would be great as I am a bit of a visual man)
Ian.
u need t ogrind or file down the 4 bolt hole areas about 1 or 2 mm and about 25mm into the bell housing
its better if you have a loose 12V flywheel to test it with so u can see how much to take off
hellbugged ·
http://forums.aussieveedubbers.com/viewtopic.php?tid=38560&page=10
right down on the last post........
have fun, work clean, there is a myth? about it all catching fire. degrease before you start
dangerous ·
If it is any help,
the outside diameter of the 12V FW is 276 to 277mm,
And it protrudes into the bell housing about 36 to 37mm.
use a flapper disc, not a grinding disc 👍
555bug ·
jam it in there and hit the starter 😉
