Although it's a bit late to start this thread, I thought I'd throw up a few pics of what I've been up to in between bouts of resto-ing Derek and Lee's camper....maybe this is why I never get to work on my own cars anymore!
Cam is a mate who lives a couple streets away from me so it made sense for me to lend a hand late in the resto of his bay window bus.
Here is how it started - overall pretty solid but again some hidden rusty treasures hiding under the paint.
Rust repair panels were tacked in place and filled over by a panel shop, and some of the basic panel work was done at the same place.
The bus sat in its etch primed state for a while as Cam was pretty flat strap with work so limited progress was made, so he hit me up for some help over October and christmas/new year.
Cam shot it with high build primer and guide coated it early October but then it stalled for a few weeks.
Dasdubber ·
At this stage you would think it was pretty close to paint however I spent around 25-30 hours straightening some of the previous work especially the nose and drivers side panels. The bottom edge of the pressing was very wobbly, as well as the lower edge of the windscreen recess, and the a-pillars where it meets the doors.
I had the bus at my house mid Oct under the temporary carport because of the rain!
Lots of sanding, filling, guide coat, sanding etc later and the front doors and nose were done.
The bus then went back to Cam's so I could resume work on Derek and Lee's bus.
Dasdubber ·
Side panels had been hit at some stage and were repaired - again I could have spent a lot longer getting them perfect but Cam intends to use his bus for camping with his family and didn't want a show bus. There were a few wobbles here and there that will show up in paint, but it takes so long to get these big flat panels perfect.
So after quite a few more hours, the bus was back in high build primer ready for its final sand before paint.
As a favour for Cam since he spent all new years day looking for my dog with us after she escaped due to new years fireworks, I decided to give his 2L and quick rebuild/check/tidy up.
You can see it needed it!
Dasdubber ·
Savannah beige was the colour of choice for the bus (and cloud white for the roof)
The beige had to be a single stage acrylic urethane, however with advice from the paint supplier, I was able to overlay it with a few coats of 2K clear to really bring up the gloss (although for the inside no clear was applied - just the outside). However the bits that were exposed and not covered by trim like door edges etc were cleared.
Cam sprayed the engine bay with anti chip paint which can be painted over with colour as seen here:
Dasdubber ·
Roof colour could be done in single stage or 2pack - the latter was chosen so the base was applied then 3 coats of clear.
Dasdubber ·
Sliding door runner mount threaded nut was shagged so it needed repair:
It was cut out, and a repair piece made with nut welded to the outer skin.
Welded in and ground smooth - another problem solved!
Dasdubber ·
Heads were filthy but in good condition as there were no cracks, and all seats/guides etc were in good condition - they would have been rebuilt at some stage in the past.
Body was shot in paint earlier this month:
Beige looks good against the white roof:
Body will be colour sanded probably early Feb - I need a new clear coat gun as mine is not atomising as well as it used to (or at least need a new cap and needle) as despite recommended pressures used, finish came out a bit peely as per Derek's bus. I made sure there was adequate build up though to account for colour sanding....just need to shell out $600 on a new gun - ouch! (but looking forward to it)
Dasdubber ·
One lobe on the cam was shot, so luckily I have my old reground 2L cam from the ragtop that was replaced prior to warwick...so that will go in along with the resurfaced lifters.
Had the case cleaned, and painted it up yesterday (pics later)
Heads looked much better after blasting as well:
Cam detailed his rebuilt 2L box the other day:
The ugly dis-used emission control tubes were removed and replaced with M10x1.0 bolts to tidy up the appearance of the heads.
The ports were blended into the seats as there was a slight step/ridge present - nothing major, just a bit of a tidy up.
Valves were cleaned up and heads reassembled last night after grinding the keepers slightly so they no longer touch eachother. Valves were lapped so heads are now ready to go back on.
Dasdubber ·
Here is my old cam back in (rivets holding gear onto cam have been replaced with countersunk bolts for extra strength).
Case was buttoned up - thanks to dangerous (Dave Butler) for pressing the fan hub off the crank yesterday arvo - that bloody thing was so tight it was unbelievable!
All the bearings were still spot on despite the ugly appearance of the engine externally. Cam and crank bearings were all excellent along with rod bearings.
Thanks for looking.
Alan
bond ·
i think the forum needs its own das resto page. where you can number them etc.
nick
geez your neighbours must love you !!!!!!
Dasdubber ·
I didn't do much of Cam's bus at my house at all so all is good!!
Birch Green ·
Brilliant job as always - love your threads! The work you do is amazing.
Great colour choice also...
Dasdubber ·
After a busy long weekend, I've found a bit of time to get back into Cam's engine. After shortblock was assembled the other day, the pistons (with rings in situ) were loaded into the cylinders from the top. I won't go into too much detail as there are a lot of good resources to build an engine if you are so inclined.
I use a high temp silicon under the barrels between case and barrel spacers and the barrels (that is the red stuff at the base of the cylinders).
There was no point painting the cylinders as it will just burn off anyway, plus the rusty appearance is normal for used barrels....and will be covered by the cooling tin anyway! After heads were torqued down (to 12ft/lbs first in a particular criss cross pattern, then to 23ft/lbs), the pushrod tubes were inserted (using Curil-T to aid with sealing both on the case and head ends). Pushrods came next (after lifters of course - I used my resurfaced lifters which were done when the cam was reground), then rocker assemblies.....and then valves were adjusted.
Rocker covers clipped in place, and numerous other bits installed as well. You can just see under the oil cooler is a full flow adaptor that I've donated to Cam which replaces the oil filter and allows you to run the oil through the filter (remoted on a bracket elsewhere), then up to an oil cooler, then back into the case. IF you have the engine torn right down and have a few more $ to throw at it, its best to have the case oil galleys drilled and tapped....then a full flow pump can be used and the return is directly into the case so the stock oil filter location can be retained. The above method is fine though unless you're really pushing the horsepower envelope (not likely in a heavy bus).
So now once Cam gets back from playing around on a boat, I can start to put the sealing tin back on and get the assembly finalised.
Alan
Dasdubber ·
Spent half of today around at Cam's commencing the colour sanding - managed to finish the passenger side rear 3/4, both rear corners and the back of the bus.
The photos were hard to get in the light, here is the rear passenger corner:
I'll get back over there at some stage soon to keep it moving along!
Alan
Dasdubber ·
Spent some more time today annoying Cam - the drivers side rear quarter and middle panel are done now. Here the rear quarter is buffed already, and the middle panel is dull after sanding it with 1500, then 2000 grit paper on the short throw dual action sander.
Nice and glossy yeh?
I'll get back to do some more when time permits!
Alan
Dasdubber ·
After a few weeks off (combination of being sick, having to do a heap of yard work, organising and preparing for a big party we had etc etc)....I'm back into Cam's bus!
Cam got the remaining engine tinwear to me late last week so the engine assembly can continue. The fan housing looks good now in a hammercoat type finish. There are a few bits missing that I'll pinch from Cam's spare engine so I can continue on.
As the fan housing has been powdercoated, many of the screw holes have been caked up such as the one pictured below:
...so I spent some time the other night tapping out each of the threaded holes.
After work today I swung around to Cam's and colour sanded the drivers door - a few hours later and all was sweet....ran out of light for a decent photo but you get the idea. now just the nose, passenger door, sliding door, rear hatch and engine lid to go!
Rod, if you're seeing this - don't panic, I've been tinkering away at your chop top and it's all under control 🙂
Dasdubber ·
Just wrapped up for the night - rebuilt one of the carbs with a new gasket kit inc. accelerator pumps/diaphragms etc.
The majority of the engine sheet metal is also on along with the thermostat and flaps etc
All exposed sheetmetal hardware has been replaced with stainless allen-head screws - I polished the heads on the buffer (on the bench grinder)...came up nice and shiny (sorry for the dark picture). All of this is not really necessary but I really enjoy being picky and focusing on attention to detail. Even though Cam's bus is not a show bus, it will still come up a treat!
Al
Dasdubber ·
Today was a pretty productive day as the colour sanding was completed on the nose, passenger door and sliding door (ran out of time for the rear hatch and engine lid - will finish tomorrow!)
Dasdubber ·
Just another quick example of why one colour sands...if you look at the gutter line of Cam's next door neighbour's house (or the cutting compound bottle I'm holding), you can see the distortion of the image like its rippled....this is orange peel - this is not terrible by any means but not good enough for me as I wouldn't want my car looking like this, so I would not leave someone else's car that I painted looking like it!
Colour sanding: 1500 first, then 2000, then a fairly new product I thought I'd try to give my arms a rest - 3000 grit Trizact paper used wet (rather than dry like the 1500 and 2000).....all of this is on the small orbit dual action sander (the Trizact uses a softer interface pad).
After the sanding, cutting compound was used with a firm compounding pad, then a softer pad with swirl remover. Once the windows are back in I'll finish up with a machine glaze and wax.
Ran out of light but here is the sliding door finished just before I headed home.
Al
squizy ·
Looks shite as always. 👍👍 Top job Al.
Dasdubber ·
Finally, all colour sanding is done on Cam's bus!
Now he just has to get into it and get some bling on (wheels/trim etc) to really show off that paint!
As I've said all along, the sides could be straighter....but lots of time = lots of money, which wasn't warranted for this application.
Dasdubber ·
Repainted the inlet manifolds and bolted up the fresh carbs...looking good!
Dasdubber ·
Had a quiet friday night at home so I tinkered a bit more on the donk - before bolting on the exhaust headers, it is essential the mating surfaces are square so they seal effectively on the heads. Cam had painted them with high temp paint which provided a good black surface to start with (you can use permanent marker/engineers dye etc instead)
With a long file (this one was just long enough but could have used an extra few inches [story of my life....hehehe]), 'machine' the mating surfaces evenly (don't do them individually or else you could take too much off one stub pipe compared to the other creating a sealing issue again.
Here it is half way through - you can see some shiny metal and some black....basically (within reason), you keep going until it is all shiny metal and flat.
Like this....
Dasdubber ·
The headers were bolted back on along with some of the final sheet metal.
Just have to paint the linkage and then hand it all back to Cam!
Dasdubber ·
Speaking of which, a few cold ones are being knocked back after another days work.
Today I polished the down rods for a little highlight - I gave them a thin clear coat to keep them shiny.
The linkage cross bar was painted same colour as the manifolds in high temp engine enamel and bolted back up again with stainless fasteners. Home stretch now!
Dasdubber ·
Just a quick update - Cam picked up his engine today...here it is before it left my stables:
Cam will polish up the air filter box a bit to tidy that up but otherwise it looks pretty nice - and will be easy to keep clean rather than having something that is very light in colour.
Visor will go onto the bus at some stage - before painting it I wanted to seam seal the aluminium trim so water doesn't ingress and rust it from the inside out (have seen this happen on some original visors). Masking tape keeps the seam sealer tidy:
Here is the sealer, after this pic the tape was removed whilst sealer is still went so it flows onto the visor and doesn't leave a hard sharp edge.
Dasdubber ·
Cam needed his dash repainted as it had some 'fish eyes' from when he painted it which is like a reaction to silicon/debris deposits on the surface under the paint. After rubbing them out, I reprimed and repainted in the savannah beige:
Also the visor received primer this morning then white base coat and clear. Unfortunately got a sag in the clear as the light wasn't the best (couldn't see how the paint was laying down very well)....but the run will be fixed with some colour sanding on the weekend.
BenettonVW ·
Nice as always Al.. I have a splitty waiting here for ya..
rocknrob ·
Alan next time yer dog goes missing can i have first dibs looking for him?😂
Dasdubber ·
BenettonVW wrote:Nice as always Al.. I have a splitty waiting here for ya..
Sounds good mate!
rocknrob wrote:Alan next time yer dog goes missing can i have first dibs looking for him?😂
I'll let you know but hopefully she'll be staying within the confines of the yard from now on! hehehe
chris smart ·
ow man this is a sweet resto cant wait to ssee some update pics haha lookin sweet as mate keep it up
Dasdubber ·
Thanks Chris....update:
Today I had to give the bumpers a bit of attention - the front was nice, only one coat of primer to sand off. After taking it back to bare metal where I could, it was treated with rust inhibitor:
The rear needed a few repairs like a patch which was for the trailer light fitting:
After butt welding it in, it was ground back and Bob's your uncle so they say.
Other holes were welded up as well which were no longer needed and the tow bar brackets which had broken off were repaired as well. The rear bumper had about 7 coats of paint on them so I had to go and annoy Cam (and his wife who I am sure is getting sick of seeing me around!) and grind it all off there...once stripped it was rust inhibited as well.
Dasdubber ·
The valance had quite a few coats of paint as well:
And was stripped back to bare metal as well:
A few other updates from Cam over the last few weeks....gear knob was custom carved by a renowned tiki carver on the gold coast:
Gave Cam a hand a while back to put the freshly painted visor on:
The headliner was installed by a trimmer on the goldy as well:
Dasdubber ·
Few more pics:
The detailed box went back in as well:
Engine went in the other night:
Other bits of detailing/reassembly the Cam has been busy with:
Repro Fuchs in bay window pcd:
Hopefully front will be loosing a little altitude at a later date.
Front seats were in a leather which Cam had left over from a job on a luxury yacht which he details/skippers etc.
Harley Davidson mirrors are a nice change from the norm:
Got the engine running last night but there is some linkage or gearbox problems as he can't get all the gears - so the bus will go to volksmod for a quick tune and box investigation.
Bumpers should see paint hopefully this week or next weekend.
Al
Brad ·
1st - You are a freak ... if this is what you do for a quick, none show quality job.
2nd - Like Rob, next time your dogs gets out give me a ring and I will fly back to OZ and help you look for it if you will rebuild my engine as a result .... 🤪
Keep up the good work, there is not enough people left with such attention to details and pride in their work ..
Lastly, in case you missed it you are a freak .. 👍👍
LIFE IN THE LOW LANE ·
Definately needs a lowered stance. Then it would look sweet as!!
ovalbug ·
Hi Alan, been watching this resto with interest great job! Just wondering how you went about applying the 2k clear over the beige single stage acrylic urethane beige, was it done wet on wet or did you need to rub it back first.
Regards
WAYNE
Dasdubber ·
Wet on wet with appropriate flash time. Trust me I double checked with the paint rep before I went down this path! (triple checked in fact) 😉
Thanks Brad and Brenndan....hopefully the front will come down at some time soon.
Birch Green ·
SUPERB! Absolutely love the work you have done, great colour(s), with the rims all looks brilliant.
Can't wait to see it dropped now...
Dasdubber ·
Cheers mate!
Today Cam got his bus tuned (all good - just needed a new dizzy cap and points)....gearbox issue was just linkage adjustment as expected. He had a fun drive home when the accel cable freyed and got caught in "full throttle" position on the M1 - he managed to get home unscathed without damage fortunately.
Whilst I was priming Rods front guards, I shot Cam's bumpers as well. A few small repairs to come then they will get their coats of cloud white and clear.
Dasdubber ·
Bumpers are now in paint - 3 coats of base (cloud white) and 3 coats of clear.
