WTB for '72 Type 3 square
https://forums.aussieveedubbers.com/threads/67225/wtb-for-72-type-3-square
karmann54 ·
I've just got a '72 square on the road and need some bits and pieces. Brisbane preferably, although the smaller bits could be posted.
- windscreen and chrome trim (and if someone has a new rubber left over, otherwise I'll just get one from one of the VW shops)
- rubber mat for rear storage area
- black knob for the drivers seat tilt adjustment
- oil-bath air filter inlet rubber sleeve (for a 1500 single carb engine, side draft Solex 32PHN carby)
I'm also after a tow-bar, may have one but in case that falls through. Only to tow a catamaran, doesn't need to be heavy-duty as boat and trailer are probably only 300kgs.
There will no doubt be more as time goes on. There is a bit of a rattle from the passenger side engine support but need to look at it more before I know what I need.
Angus, 0412 105 789 or just post reply/PM.
bushed ·
the supports sometimes crack in the body and may need welding b4 it drops !!
type3kid ·
might have the knob you need man, if i do i'll let you know.
karmann54 ·
bushed
found the reason for the rattle - cracking in the body support. not the 'main' section but the piece on the bracket folded over onto the body. Not about to fall off but if I leave it go the crack will move around onto the main support. I can't weld but can take it to work and get it fixed.
type3kid
If you have that knob that would be great.
May have found a windscreen at mick motors, mine has some star chips and I only got the RWC on the promise that I'd replace it ASAP!
Thanks for the replies
Angus
Andy ·
Cracking there is not uncommon!
Make sure you have a good look where the bumper bolts to the body, they rust out from the inside. I'd be very worried about towing with a type 3.
karmann54 ·
Andy
I'll check there. The car has spent most of its life on the New England Tableland so is pretty good for rust. I'm changing that as we are about 250m from the water at Wynnum/Manly!
I've remembered I need a window winder as well, plus the retaining set screw for it.
Angus
I have a brand new NOS rear rubber mat
type3kid ·
hey man. email me a pic of the winder you have in your car now to ablancato@hotmail.com i have a few spares at home but they are all different so i can match that up to. if i've got the knob i'll post them all together
karmann54 ·
type3kid
No problems, I'll take a photo of the winder tonight and send it off.
Angus
type3kid ·
sweet man. i'll have a look either tomorrow night or on the weekend, pending what time i get home from work. if i have any of the parts i'll put them in the post early next week
vince4avd ·
I could have a tow bar, I'll have to dig around...also I'm in Sydney - but have a freight contact that is very economical.
type3kid ·
hey mate. dom't have the winder you're after. have the standard black set spare tho. sorry no seat knob.
Is that the big round one on the bottom of the seat
or the small one on the side of the back support about half way up ??? that you lift up to allow the seat to go forward so u can get into the back seat
karmann54 ·
Thanks for looking Aaron.
Dave, it is the knob on the middle of door side of each seat base used to adjust seat tilt. I'll have to look again but on mine the 'access knob' on the seat back to get into the back seat is the large one, the seat tilt one on the base is smaller from memory. I'm having a few typical teething problems on a car unused for a few years, so not certain I'll be getting to Dubs in it. If not I'll just pick up the rear mat at Boondall.
Angus
Angus
we are going striaght to the Pub not going in the convoy
the square knob on the seat base is to adjust the back n forward movement of the seat base
the round knob 50mm is for the adjustement of the seat back about 10 clicks
so which one is it ???
karmann54 ·
My seats have three different knobs to control things.
There is a square knob beside the tunnel which is used to slide the whole seat forward and back - controls a pin under the centre of the seat.
There is a large knob on the outside edge of the seat back which you slide up to tilt the seat forward in order to get into the back seat.
There is a smaller black knob on the outside edge of the seat base which is used to control the angle of the seat back. It is this last one that I am after. I'll try to get a picture, I may have an odd seat? I don't know type 3s but they look like the originals.
Angus
