Im after a set of front and rear brake calipers off a Subaru WRX from 01-05.
Anybody?
Thanks, Andrew
GTMac ·
https://forums.aussieveedubbers.com/threads/67228/wtd-brake-calipers-off-01-05-wrx
GTMac ·
seagull ·
GTMac ·
seagull ·
GTMac wrote:Seagull,
Actually not for my VW this time. I am sourcing a set as requested because they are an upgrade to what Suby put on the B4's, pretty stupid that the B4's didnt get atleast the same set up as the standard WRX.
ok I never would have thought !
Thanks for your info...................now that you know what I actually need them for, even though the R32 Front) take the same pad I dont assume they have the same mounting holes etc to bolt onto the Suby?
no you need an adapter for this
So what you are saying the rears will bolt on and imagine you could just polish away the NISSAN logo?
yes if you have the backing plate & the disk from a two pot rear wrx
If all I say is a load of crap happy to take a full set of WRX 01's off you if you can get them or have them.
I can get you wrx fronts & nissan rears
Now here is another one ! I have an adapter from your stock B4 rear backing plate so you can fit the lager wrx vented disk on using a nissan caliper .
The subaru brakes are expencive & getting harder to locate .I see what I can do
Thanks, Andrew
