Aussieveedubbers 路 Tech Talk
replacing the brake light switch on the master cylinder?
https://forums.aussieveedubbers.com/threads/67234/replacing-the-brake-light-switch-on-the-master-cylinder
Anthiron 路
my brake light switch appears to have given up.
i can order one easy enough, just wondering, can i replace it without losing the brake fluid etc, or will unscrewing the switch let the fluid flow from the system leaving me to re bleed everything?
Nicko
Craig Torrens 路
I replaced mine in the ragtop without re bleeding, had no problems 馃憤.......................but it would be best to bleed the system.
11CAB 路
Yeah no need to bleed the system, just make sure you have the new one in your hand when you take the old one out and swap them straight away.....you will lose a little bit of fluid but dont worry about it.
Also it should be a 22mm spanner
vw54 路
as per above it would be better to bleed the whole system after replacing besides it will refresh all the fluid
Anthiron 路
ok thanks for the replies guys
thats what i was hoping, i will bleed the system i was more worried about everything just flowing out if the hole was big enough making it one of those annoying refilling the system kind of bleeds.
excellent, ill give mick motors a ring in the morning.
vw54 路
no u will only loose a few drops if you do it quick enough and have the right tools n spares fingers to block the hole
you could pull the tank in a beetle to make it easier to work from the top
Anthiron 路
in my baja theres plenty of room underneath, i doubt ill need to pull the tank.
vw54 路
Ok so its UP in the air
4 got to say dont over tighten the brake switch just nip it up
Anthiron 路
ok thanks dave.
stevosky 路
The hole in the switch is probably full of crap
