Need a shortend sump for EJ20T
https://forums.aussieveedubbers.com/threads/67286/need-a-shortend-sump-for-ej20t
72type3wrx ·
Hey guys
I really really need a shortened sump, I have only done 400kms since the conversion and have nearly ate away the stock sump. can anyone help me out.
VV performance centre offered me the drawings of there's but I never picked them up, if you guys have them please post them or PM me
ian.mezz ·
JVL RACING IS SELLING STUFF LOOK HIS POST UP
http://forums.aussieveedubbers.com/viewtopic.php?tid=66986
GTMac ·
Likely your oli filter will then be lower than the sump unless you can get a stump version or run a remote.
72type3wrx ·
Perfect
now does anyone think that JVL's sump will fit with the standard Subaru Turbo manifold with standard heat sheilds on?
JVLRacing ·
72type3wrx wrote:Perfect
have you looked at the pics? that will help with your answer😎
72type3wrx ·
Can i have the dimmensions JVL? that will give me the answer.
JVLRacing ·
72type3wrx wrote:Can i have the dimmensions JVL? that will give me the answer.
I will pm you with them.JVL
Dero ·
Im over here in the uk at the moment... anyhow I am soon ordering one of them Cast Alloy ones form Bug@5speed.... do a google. He is located in Germany. I am heading home in March, though will be ordering it here and getting sent home to Perth...
Let me know if your interested
Joel
Bugs@5speed posts on here sometimes, do a search and you might find contact details on here. If you have room have you thought of lifting the motor up an inch or so?
JVLRacing ·
Steve, thats a waste of time! That would cause more undistrubuted weight....not a good idea.
I don't think it would matter, he's not racing for sheep stations. What would be waste is if he stuffs a motor buy having a short sump or by grounding his stock sump and loosing his oil
JVLRacing ·
got nothing to with racing steve! it becomes unbalance weight from front to back lifting motor up higher!
Hi John
I don't know why I'm arguing with you. You don't think fitting a big lump of a Subaru motor in the back of a car would not have already "unbalance weight from front to back" Shit John 25 mm or so would not be noticeable.
JVLRacing ·
1303Steve wrote:Hi John
who said we are arguing haha Steve😎 25mm still would steve.I work by the theory keep everything level especially with these motors m8.Think steve! raising a motor higher would cause steering probs (like a seesaw effect)Springs for one will become a bigger factor!
JVLRacing ·
A good made up sump is the easies solution!
That sound you can hear is me hitting my head on the computer screen
JVLRacing ·
1303Steve wrote:That sound you can hear is me hitting my head on the computer screen
dont be a smartarse steve! have you done install yet steve?🙅
Dero ·
Well from what I can gather the Bug@5speed sumps seem like a good option though pricey I guess, but right now im on pounds so that isnt the biggest issue also in the right place to sort it.
72type3wrx let me know if you want me to sort one for you if not no worrie! 👍
and mine is for a Baja...
seagull ·
Dero what is the cost of these mate ?
LOL....
Dero ·
Seagull
yeah ill double check with the bloke, but I think it is like 340 Euro incl 17% VAT, though I will get the VAT off... I know they are pricey but they look like a good option.
I am going to get him to send it home for me.
72type3wrx ·
lets all go out and buy dry sump set ups then
type2nut2 ·
Just for interests sake, can anyone provide me with any links to Subie engines with dry sumps?
newoldmanx ·
never had an adult passenger in the back of a car and got a "seasaw effect" is raising the motor 25 mm more noticable than an 85 kg passenger
newoldmanx ·
did you try custom veedub in brisvegas
newoldmanx ·
here
http://www.customveedub.com.au/store/index.php?act=viewProd&productId=1
JVLRacing ·
would be if you sat him in the engine bay🤪
newoldmanx ·
besides all the buggie(S) i own and have owned with 10deg kits in them spare wheels & mounts hanging out the back on (heavy) duty rear barwork on top of and mostly behind the engine on swb buggies
AND
owning a vw twin cab often having 700+kg of firewood and numerous other crap over the years on the back loaded very and alot of that is over the engine compartment which houses my lifted ej20t and still no seasaw.
if lifting your motor 25ml is causing seasaw you have a steering problem or a bent pan if i were you id check the front end
there is something wrong with your car
Hi newoldmanx
Thanks for your words of reason.
JVLRacing ·
AND
I just dont see the theory of lifting a motor 25mm solving a sump problem as Steve has said I did comment on this being a balance prob....I believe in reason wat you have done with your buggies work but with every day road cars🙅.....theres been alot of blokes doing subie transplants and i have never heard anybody lifting there motor up 25mm.....A bent pan no doubt would cause steering probs.
JVLRacing ·
1303Steve wrote:Hi newoldmanx
Maybe Steve you can lift your motor 25mm to prove my theory is wrong and i would no doubt say you were right even shout you a beer😎.....thats when ever you finish it!
newoldmanx ·
as i said above i believe this is your best solution you dont need a lift (more a tilt than a lift) kit
and my buggies are daily drivers!!
Hi JVL
I already have lifted it 25 mm and moved it forward 100 mm, it nearly fell off the jack stands.🙅 Im trying to get away with a stock sump. Subaru motors like to eat bearings if they get short of oil.
JVLRacing ·
1303Steve wrote:Hi JVL
Good stuff! hope it works Steve.My sump capacity had 5litres plus with oil cooler and lines 8litres all up.....
newoldmanx ·
wadda ya reckon this would do if 😂😂😂raising your motor 25ml makes your car "seasaw"🤪🤪🤪
JVLRacing ·
absolute madness🤪
