Hi, I'm having some CNC machined aluminium dash plates made up to hold 3 VDO/Autometer gauges in a line. The 'gauge' plate will sit/mount where the radio would normally be in a beetle (205mm x 70mm x 10mm) The gauges will be counter sunk and there will be some machined lines across the face.................so order yours now! (gauges not included !)
Price: $45.
PM with your delivery address and I will provide you with payment options.
Regards
Craig t
hellbugged 路
馃憤
JVLRacing 路
馃$$$$
Special Air Service 路
Craig,
My radio slot has been opened up slightly to fit a CD player, would these panels still work & cover the slightly bigger (couple of mm) opening?
If it would I would be interested in one.
Brendan
Craig Torrens 路
Yes, I have made them larger for that reason. Just check the measurements in the first post to make sure it will cover !
Also the fixing screws will be located in the rear for a "cleaner" front appearance.
berserkerbus 路
馃憤 Definitely interested.
bb
type3kid 路
these fit onto a type 3?
Craig Torrens 路
it will fit anything with a flat surface !
should have a photo tomorrow night.
Craig Torrens 路
finally done !
Craig Torrens 路
and in the car.
Anthiron 路
how much craig, im interested.
Craig Torrens 路
might update the ragtop gauge cluster......add some bling !!!
JVLRacing 路
Craig Torrens wrote:might update the ragtop guage cluster......add some bling !!!
dirty finger nails come with as well馃槀
VWCOOL 路
yeah I'll take one for the new car
Now do one for the radio grille area of an Oval!
Dasdubber 路
Do you have the dimensions for the inside diameter of the holes (the actual hole as well as the ID of the beveled lip the guage sits in)?
I am not 100% sure of the size of the VDO guages, but I'm curious if it will fit either the 2 1/16 or 2 5/8 autometer stuff.
Al
type3kid 路
looks good craig. definately interested.
just need gauge size and price please
Craig Torrens 路
Price is in the first post.....................will post dimensions tonight.
type3kid 路
how much do we include for postage?
Craig Torrens 路
$5 each Australia wide.
Craig Torrens 路
also perfect for Autometer gauges.
Craig Torrens 路
side profile.......would look good with the three in!
56astro 路
Craig Torrens wrote:side profile.......would look good with the three in!
What a 'Sale's Man'
BTW
Might see you Monday
Craig Torrens 路
make sure you ring first !!
dangerous 路
Salubrious!
Good idea Craig.
Craig Torrens 路
Cheers Dave, I wanted to make one for my car so I thought I may as well run off a batch for others !
lugnuts 路
u have mail 馃槝
Craig Torrens 路
Bump....................new batch being made this weekend.
robnjo 路
these look the bizz...u2u time馃槑
Craig Torrens 路
your order has been processed !!
Get in quick if you want one, only 3 left from this next batch.
lugnuts 路
Cooool 馃槑
lugnuts 路
and
lugnuts 路
and lastly
Craig Torrens 路
WOW that looks great 馃槏
so it's perfect with VDO, AUTOMETER or SMITH Gauges ! 馃憤
lugnuts 路
Hello Craig,yeah they look bloody great,BUT there just props.
JVLRacing 路
yeh they look alright bit more polishing maybe馃槀
THEY LOOK GOOD
Craig Torrens 路
JVLRacing wrote:yeh they look alright bit more polishing maybe馃槀
I will send them to you.................you like to have a good polish 馃槀
I have done them in a satin finish so they don't shine in your face while driving !
JVLRacing 路
impressive M8! but i want it FREE!........mole...
type3kid 路
got mine last night. not in a car yet but looks sweet as, can't wait to get the fasty going and get it in
Craig Torrens 路
post some pics when its it 馃憤
Craig Torrens 路
another batch is done and ready to go !
PM me to order 馃憤
Craig Torrens 路
a couple left...........Dumone have you fitted yours yet ?
Craig Torrens 路
馃槒
type3kid 路
hey craig. will be a while befor it's in, work on it is very slow to put it nicely. but after seeing these i knew ity'd go tops so planned ahead
Craig Torrens 路
more for sale !
hellbugged 路
Craig Torrens wrote:a couple left...........Dumone have you fitted yours yet ?
nope...........but happy with it, looks good
Craig Torrens 路
bump................will be making some more, so happy to take orders.
Brad 路
will they fit an L bug ?
Craig Torrens 路
yep 馃憤
Brad 路
got any pics of one in an L Bug ?
Ian Bugden 路
These still avail??
PM sent
BrisDubba 路
Hmmm must have missed this post previously, put me down for one if you are doing a batch.
BiX 路
Hi Craig, I sent you a PM, is there a new batch coming soon?
Drew
Craig Torrens 路
Ooops sorry Guys and Gals........yep new batch is coming.
Will let you know when they are done.
Craig T
VWFREAK 路
VWCOOL wrote:Now do one for the radio grille area of an Oval!
If you can do it for an oval, I'm interested.
Craig Torrens 路
Hi everyone.......new batch is done !!!
As for the oval plate, I'm working on that one 馃憤
Craig Torrens 路
Hi guys, I have sent PM's..........they are ready to send 馃檮
Ted2 路
I'm told that a radio block off plate from a 68 to 72 bug is the same as one for a 67 split bus. Does it follow that this dash plate will fit a 67 split bus? Thanks Ted
Craig Torrens 路
if its the same it should fit then !
hellbugged 路
Ted2 wrote:I'm told that a radio block off plate from a 68 to 72 bug is the same as one for a 67 split bus. Does it follow that this dash plate will fit a 67 split bus? Thanks Ted
might have too much curve in the bus dash, i think........i will check as i have access to both plate and bus
Craig Torrens 路
I'm about to do another batch of these dash plates, so if you want one then just send me a PM
I have two plates left from the last batch @ $40 each plus postage.
Craig Torrens 路
bumpsie
Craig Torrens 路
one left...... $30 plus postage 馃憤
gaz58t2 路
Hi Craig
I will take that last one if still avalible
Will PM my details if stillavalible or you PM me
Cheers Gaz
