Aussieveedubbers 路 Tech Talk
Drop Spindle fitting
https://forums.aussieveedubbers.com/threads/67408/drop-spindle-fitting
marty_08 路
Just grabbed a set of drop spindles (for a ball joint and disc front end on a 68 chassis).
Is it a big job fitting them in your garage??? Anyone found a walkthrough???
The rear is lower than stock so do i need camber adjusters??? Best to fit them anyway???
Any other tricks i should know about?????? 馃
Any help's great!!!!!!
Marty
sinecure 路
http://www.thesamba.com/vw/forum/viewtopic.php?t=256755
Only info I could find.
I haven't done it, but really, it should equate to a straight swap, just follow the manual. Your wheel alignment will probably need to be corrected.
Come on AVD! Plenty of you must have done it.
Bizarre 路
sinecure wrote:Come on AVD! Plenty of you must have done it.
Nah..... long live struts 馃檯
馃槀
matberry 路
Just finished an early. Late is easier if you can get the b/j tapers out of the orig stub (2 outer tie rod ends as well).You may need a b/j removal tool but most of these damage the dust boot. If your ball joints are worn, now is the time, and if so maybe a vw shop would be best as a 10 ton press is reqd (min). Awheel align is a must after installation.
