Spring length???
https://forums.aussieveedubbers.com/threads/67571/spring-length
Old Hutcho ·
Help guys.
I need to know what the uncompressed length of the spring in the pressure relief valve is (in a dual relief valve case, the one closest to the flywheel) and its effect of oil pressure and engine cooling.
Mine is currently 36.5mm long and the engine tends to run hot with low oil pressure. I think the two are related.???
regards.
Old Hutcho
Old Hutcho ·
Bump
Old Hutcho ·
Come on fellas. Its a real easy question. I really need the answer.
dangerous ·
Old Hutcho wrote:Come on fellas. Its a real easy question. I really need the answer.
It WAS Sunday, and everyone probably keep their spares away from the computer.
The only one I have is actually shorter than that one you have.
It is common for old or worn,
or poorly assembled or machined engines to have low pressure,
and a "booster kit" is available with a longer stiffer spring and an adjuster in the threaded plug.
But this item, and the larger oil pumps people always fit, MAY increase your pressure,
but are only covering up for some other more alarming problem.
EG, worn case, bearing surfaces or relief piston hole and seat.
