I'm after the control box on the inlet of the air filter to a single carb (Solex 32PHN) type 3 motor.
This is the metal part with a weighted flap. It is clamped to the car body air inlet, then there is a rubber bellows between it and the air cleaner.
part # is 311 129 609B.
I'm also after a black face tacho to suit a '72, I think they are the same size as the clock?
Any help appreciated.
Angus
type3kid ·
as in the taco that has fuel etc..?
karmann54 ·
I thought there was one in the same style as the later gauges which could basically replace the clock, tacho only. I seem to remember seeing one here or on ebay a while ago. My clock doesn't work (which seems to be pretty standard) and I picked up a small period VDO clock I could fit under the dash at Dubs by the pub.
The tacho is probably not as important right now as the control box (not sure if that is the right name for it).
