Single side plate box length
https://forums.aussieveedubbers.com/threads/67769/single-side-plate-box-length
PUNCH_BUG ·
Does anyone know, or have a single side plate bug box lying around that they can measure, to tell me the length of it?
From the face that bolts to the motor to the, end of the shaft.
Thanks.
dangerous ·
670mm
but the input shft sticks out about 10mm,
and the shift rod can move in and out 10mm or so from that point.
its the same length as a stokc twin side plate or even a swing axle
what is it your wanting to do ???? swapping between years models is not a prob
PUNCH_BUG ·
Thanks dangerous, and vw54,
Im just comparing the difference in length between the single side plate and my kombi 2ltr box that has been created for my bug.
Dero ·
Hey Punch Bug... let me know if ou dont want the 2 ltr box... :P
Flintstones ·
Hey Punch Bug,
what's the length of the 2Lt box?
also what are the height differences between the 2 boxes (at the shift side) if they are both sitting on the floor?
D
PUNCH_BUG ·
Dero, do you want the albins gears and super diff thats inside it as well? :P
Flinstones I dont have a 1600 box anymore to compare, but i will measure it up.
Dero ·
I definatley would consider, as i too have a EJ motor for a conversion... so if you are considering getting another box I could be interested!!
Flintstones ·
PUNCH_BUG wrote:Flinstones I dont have a 1600 box anymore to compare, but i will measure it up.
Thanks punch bug would appreciate it.
