Part numbers for 36HP?
https://forums.aussieveedubbers.com/threads/67815/part-numbers-for-36hp
Pastit ·
Got a few bits and trying to see what zackery they are
Camshafts underneath the number 113.109.111A
is 320H
15H
20H
H1E
17H
3
Any of these 36 HP one's?
And heads under the number 111 101 371A
is 371A
39
27
16
5
Any of these 36 HP one's as well?
Heads and cams in 36 hp are obviously smaller in size, should be easy to tell.
the 36hp heads usually havea steel insert in the spark plug hole / thread also where the rockers bolt on the rocker saddles are sunken and not flat allowing half of the rocker shft to sit into the head if that makes sense
the 36cams are shorter than the 1200 and 1600 engines
36 hp stuff usually has a 111 xxx xxx part number. 36 hp cams have shallower bevel on the gears than 40 hp - 1600 ones. The the top cylinder head nut hole on 36 hp heads enclosed.
Pastit ·
The 27 and 39 heads have recessed top cylinder bolts and have the half recessed tappet mounts.
are u selling or trying to build an engine ???
where r u located
Pastit ·
vw54 wrote:are u selling or trying to build an engine ???
where r u located
Niether at the moment, just going through a shed full of stuuf to see what I've got.
