On a blade type bumper bar, do the 'mounts' or insert bits go on the front bumper and rear bumper or just rear bumper?
The bit that sits between the bumper and the bracket.
they are fitted to all ends of the brackets so you need 8 off 4 for the front bar and 4 for the rear bar
you also need the correct square underhead bolts to lock the bars in place
Mick058 ·
yeppo, cheers, thanks Dave
how many do you need ???
they tend to bend easy as well so make sure they all sit and the same height and level when sitting on there ends other wise it will throw the bar out of alignment you might have to fit the bar to the car and do a bit of pushing n bending before it gets painted or chromed check all the gaps to the body when you do this as well
nuthing worse than following a car with crooked bumpers or having too big a gaps etc etc
Mick058 ·
Agreed, crooked bumpers are frustrating
Mick058 ·
im sweet for these, i have about 16 of them. Thanks Dave. front bumper is on and straight...i think
sit the car on a level service and use a tape measure at the outer edges to the floor you may have to yank n push the bar a bit also check the gaps from the outer edges to the guards these should be even as well
make sure the tyre pressure are all even before hand
