WTD....type 3 case
https://forums.aussieveedubbers.com/threads/68230/wtdtype-3-case
Stanley ·
I'm chasing a late model type 3 case. The type that has the holes for the rear mount. The case out of my notch has seen better days.
Don't care if it needs machining just as long as it's a good base for a rebuild
Contact me on 0423775037 or stanley111@optusnet.com.au or send a PM.
vwsteve ·
i can give you a good motor for 500?
type3kid ·
where is willowbank? i have a few cases lying around you can take one cheaply if you like
so r u building a BIG engine or a stocker
If your building a BIG engine then you should really go with a new case
otherwise you will be paying good money for garbage
Stanley ·
stock engine for a daily driver
Ok make sure all the surfaces true and the case hasnt been bored out previously etc etc lots to check
Stanley ·
Thanks 👍.... Old case had an ugly rear main from having 1/8"+ endfloat causing the main seal to leak. Also one of the studs was cracked into the oil gallery which made for another annoying leak. Thought it was time to do my bit for the environment.
Ok you can fix the rear main with a macine and space job have had this done before and works OK
but the oil gallery is another problem
4 got to say you want a universal case as well to have the rear mount and oil dip / filler hole for a Type 3
"" Thought it was time to do my bit for the environment""
thats what degreaser is for LOL
Stanley ·
unfortunately the cat (with the tail like a possum) chased a grasshopper through the drip tray and then preceeded to paint the garage with it's oily tail.
I blame the cat, however my wife blamed the car and "recommended" that I fix it or park it outside.
Still think a better option is to get rid of the cat...😀
