larger valves in a 2.0lt head
https://forums.aussieveedubbers.com/threads/68291/larger-valves-in-a-20lt-head
dlwrede ·
Hey guys,
it is sounding like I may have a stretched valve or dropped seat in my 2.0lt 79 bus. The number 3 cylinder keeps getting hot and the tappet goes tight. If I have the dreaded dropped seat syndrome and are up for a new set of heads then is this a good time to increase the valve size to that of the 1.8lt (41 intake & 34 exhaust) as in the future we plan on changing the cam to a slightly hotter hydraulic cam.
Does this sound like a good move or does anyone have any feedback on this or a better valve/head combo's?
cheers Derek & Lee
MickH ·
Just get 1800 heads.
11CAB ·
Only problem you might have is if the heads you have are running square ports. The aircooled engines in the square T25/3 Kombis had squarish exhaust ports which means your exhaust wont fit the earlier 1800 heads......
Not sure if your 79 heads have these square ports
dlwrede ·
Is there a easy way of telling if the exhaust port is square? can you tell by looking at the manifold?
Does anyone have an idea on cost for replacing heads and perhaps a set of rings while the heads are off?
Is there anything else that would be crazy not to refresh while undergoing the knife?
Derek
