I have just assembled another engine that has the following components ;
new as41 magnesium universal case
new cro-moly 69mm 8 dowelled crank
new cro-moly 5.4'' conrods
new engle w110 cam
new steel straight cut gears
new scat solid lifters
new KS main bearings
new KS conrod bearings
new Mahle dual thrust cam bearings
new bearing dowells
new crank install kit
new case install kit
new case hardware kit
new dizzy drive , shims and spring
new lightened flywheel and shims
new rear main seal installed
new sump plate and strainer
all assembled and ready for a top end priced @ $ 2350 . I can also supply all parts to complete this engine , ROD , 02-42729920
RodPenrose ·
