how hard is it to replace genny bearings?
https://forums.aussieveedubbers.com/threads/68574/how-hard-is-it-to-replace-genny-bearings
Anthiron ·
well the title says it all.
how hard is it to replace worn bearings in a generator? type 1 if that matters.
Nicko
OZ Towdster ·
Not that hard and we have the bearings in stock @ Custom Vee Dub 33564356
Anthiron ·
hi andrew
do i just unbolt the fan assembly and it all comes apart? will i need a bearing puller?
OZ Towdster ·
you won't require a puller i believe , but it has been a while since i looked at a genny nick
Anthiron ·
ok well ill pull it apart tonite and see what it looks like. thanks for the tips
type3lover ·
From memory you won't need a puller and the bearings are very common. Cost less than $10 each when I did mine.
