Aussieveedubbers 路 Tech Talk
pressure plate difference
https://forums.aussieveedubbers.com/threads/68639/pressure-plate-difference
pod 路
is there any difference with using these 2 different pressure plates,old one is on the left ,new one i had of a 1200 motor i have sitting around,changing as the old one keeps losing its springiness on longer runs(think its losing its height) ,plus motor had to come out as the throw out bearing came unhooked after changing the clutch cable(doh)馃槵馃槧
hellbugged 路
no difference
diaphram one is the updated model, smoother operation too
put a big dob of silicon on the bearing keeper pins where they go into the throw out bearing itself, to keep em in
pod 路
thanks Daimo ,will do about silicon on pins馃憤 ,once i get new bearing as other one is quite dry in the lubrication department馃憥
hellbugged 路
sorry, assuming that they are the same size of course, 180mm or 200mm
geodon 路
Mate, I can't see how the clips would fall off during a cable replace, UNLESS:
(a) the return spring is stuffed, causing the bearing to flutter
(b) the holes for the clips on the bearing spigots have "ovalled" out causing the pins to fall out.
(c) the "cut-outs" on the yoke that push the bearing have worn making the pins a sloppy fit.
If motor is down best check & replace as necessary
