BOOST
https://forums.aussieveedubbers.com/threads/68647/boost
ian.mezz ·
What sort of Boost are people running on their Subaru VDubs????.
What sort of Boost controllers??? if any.
I am looking at a Turbo smart Boost tee $90 the little blue one.
GTMac ·
15psi and yes i use the same blue Turbo Smart unit.
ian.mezz ·
I got one of the Go Fast Bits Controlers for same money as someone told me they are better
GTMac ·
ian.mezz wrote:I got one of the Go Fast Bits Controlers for same money as someone told me they are better
How dumb am I, I just looked and yes I have a GFB and bought it as I was told they are better 🤪
boof2332 ·
I had a dual stage turbo smart so I could switch between 12 and 17 on the dash...It started playing up after a while and now have a GFB also. If you have silly money then get a digitally controlled one...you can have them programmmed for different boost in different gears and revvs. Also control water sprays etc. $500 approx.
matt
72type3wrx ·
theres ones on ebay for like 30 bucks that do a great a job - http://cgi.ebay.com.au/Turbotech-manual-turbo-boost-controller-THE-ORIGINAL_W0QQitemZ190218685301QQihZ009QQcategoryZ130654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
heres a article about it from autospeed - http://autospeed.com/cms/A_2687/article.html
I was running 14 PSI on my old VF10, soon as my VF34 P20 is on its gona be set at 20 hopefully.
LIFE IN THE LOW LANE ·
The autronic ECU my brother is running on his Type 3 has boost control settings programmed into it. we will utilise the 2 stage boost set up like having a boost controller with a switch to have either 8 psi or 20psi. Can also set it up to set boost in each gear which could be good to avoid tranny expiration LOL
