As they dont make scraper rubbers with the associated alloy trim for the Type 3's (as far as I know) and people are using modified Beetle ones I thought I would have a go at doing something. Sure it will work just as well and a hell lot cheaper. Prob about a 1 hour job to do both.
Most people will have scrapers that look like the above and of course let in plenty of water. No wonder they rust out the bottom, warp door cards and stuff speakers when fitted.
I have used what I believe are Kombi inners that have the spring clips.
Dismantling is easy by just drilling out the rivets and you are left with the outer alloy mold, old rubber and the metal backing plate.
I first held the new scraper into position at the curved end and marked each hole position corresponding from the trim. The inner rubber is shorter than the original rubber but allows for a hole placement close to the bottom. Once each hole was marked I drilled each position (you can see a hole in the rubber just above hole 2 on the alloy trim), realigned the rubber and pushed a rivet through all six holes. I was just a matter of then placing the metal backing plate back over each rivet and pulling them tight.
Looks a little wobbly at moment but that is due to it being slightly out of shape when it was removed. When positioned back in the door and pushed back into shape it should be fine.
GTMac ·
I posted this in the Type 3 section as this is what I did it for but guessed it may come in handy for others with Beetles or possibly Kombis even though you can buy your kits it may save some dollars.
Looks like a bought one... lol..
I see You have used a quality rubber scraper too...
the ones i bought, all the clips broke off [Brasillian I guess]
so i glued it in place
Vintage has some Type 3 complete scrapers available but there hard to get
GTMac ·
vw54 wrote:Vintage has some Type 3 complete scrapers available but there hard to get
And at what price would these be?
penguin ·
Dunno
I bought a pair of Type 3 scrapers from Micks not oo long ago, they are leaning up in a corner of my house waiting for the project to go ahead. Good luck though, looks good so far,
Notch Nut ·
A practical solotion to a common problem👍👍
Great work.
- Adam
GTMac ·
penguin wrote:Dunno
Yes there is NOS laying around if you can find it but its still carrying a good price tag. I think what I have done is do a solution for the majority of peoples daily drivers that dont want to spend the extra cash. I would buy or find a set for a full resto job.
use yr fingers and call for a price 9789-1777
GTMac ·
vw54 wrote:use yr fingers and call for a price 9789-1777
Dont need to, made my own 😎
GTMac ·
OK, took up the option and called Vintage re the Type 3 scrapers and yes they have repro's for the $$$ saving price of A$105 each............................so I stick to my initial idea of saving some $$$ for your non show daily driver. My cost was $20 per side and a few hours work.
whereisfelicity ·
for future reference i purchased some from vwispwest.com cant remember the price but they fit pretty well and i havent noticed any leaks
GTMac ·
whereisfelicity wrote:for future reference i purchased some from vwispwest.com cant remember the price but they fit pretty well and i havent noticed any leaks
They are the Ebay seller from memory. Yes they heaps of VW stuff but it can be hit and miss with the quality from them but good to hear they seem OK. Wonder where they source theres from, WCM possibly?
