1600TP SPECS????
https://forums.aussieveedubbers.com/threads/68873/1600tp-specs
ashman1111 ·
hey guys just have a quick one for most of ya? can someone give me the specs for tuning my 1600TP...
ie dwell, timing, and vavle gap??
thanks,
ash
Valve gap: .006 (.15mm)
Points Gap: .016 (.4mm)
Timing: 7 1/2Deg BTDC (static when engine is COLD)
ashman1111 ·
GOOD ON YA CRAIG....thanks
Do You have a pic of your engine?
what Distributor are You using?
if it ends in 009... its a common replacement distributor that needs to be tuned at maximum revs using a strobe timing lamp at 30 degrees... [28 to 32]
check out Rob & Dave's website
everything you need to know is there..
http://www.vw-resource.com/table.html
best of luck
PS: items with yellow dots not original parts..
items marked green are for the semi automatic
items marked blue are accessories
hellbugged ·
68AutoBug wrote:Lee
items marked blue are accessories[/b]
o dear, your engine is a real bitza then Lee😂
